The New Werks B5 .21 Racing Engine >
Like Tree63Likes
Old 08-17-2011 | 02:02 AM
  #7561
Default having a shocker
pulled the new motor and carb out of the packet, so i could assembly the motor to eliminate any material getting into , only to find that one of o'rings on the carb retainer is busted I'm having a shocker can someone please tell me what size o'ring I need to get
Cheers
sbv20j is offline
Old 08-17-2011 | 03:36 AM
  #7562
Default new pics added
Hi Ron
Added a pic let me know what you think.
http://www.flickr.com/photos/66494641@N08/6052649112/
Cheers
Simon
sbv20j is offline
Old 08-17-2011 | 08:57 AM
  #7563
Default Pipes
Have any of you guys compared a 053 to a 086 on this engine? Performance, run time, sound
K. Wood is offline
Old 08-17-2011 | 09:08 AM
  #7564
aptyk88's Avatar
Originally Posted by sbv20j
pulled the new motor and carb out of the packet, so i could assembly the motor to eliminate any material getting into the motor when i remove the rust, only to find that one of o'rings on the carb retainer is busted I'm having a shocker can someone please tell me what size o'ring I need to get
Cheers
one of mine was broken also
aptyk88 is offline
Old 08-17-2011 | 09:21 AM
  #7565
are you guys referring to a small sliver of O-Ring that is exposed?
if so its completely normal.
the tolerances are tight and once adjusted you will be fine.
Mo Denton is offline
Old 08-17-2011 | 09:22 AM
  #7566
aptyk88's Avatar
the o-rings that goes around the carb pinch bolt assembly
http://www.flickr.com/photos/6649464...n/photostream/
aptyk88 is offline
Old 08-17-2011 | 09:24 AM
  #7567
never tryed 053...tryed 086 dynamite and it wasnt bad but tuning window isnt as big as the werks pipes and the low end wasnt that great either.
I know it has been stated the Werks pipes are the way to go and I understand sometimes the bidget doesnt allow it but believe me its worth saving for... the 2013 and the 2058 are exellent pipes for any of the werks engines.
Old 08-17-2011 | 09:25 AM
  #7568
ok sorry thats a good one there! I apologize I thought you were referring to some the O Rings in the needles settings
Old 08-17-2011 | 10:58 AM
  #7569
aptyk88's Avatar
no problem man, i just figure thats important i could just use sealent but ill wait for the o-ring from Ron
aptyk88 is offline
Old 08-17-2011 | 01:52 PM
  #7570
Are b5 and b6 parts interchangeable? P/s/r?
dreaux is offline
Old 08-17-2011 | 03:21 PM
  #7571
yes they are...only difference is the sleeve
Old 08-17-2011 | 03:43 PM
  #7572
Default PM
Hi Ron sent you a PM
sbv20j is offline
Old 08-17-2011 | 03:57 PM
  #7573
you mean number of ports right? I can still use the sleeve then? I was damn near positive i could, just wanted to make sure.
Got a b6 pro on the way.
dreaux is offline
Old 08-17-2011 | 05:30 PM
  #7574
The piston and sleeve are considered "mated for life" once run. I would not recommend using the used sleeve with the new piston.
mthird is offline
Old 08-17-2011 | 05:54 PM
  #7575
alexrckid's Avatar
b5 and b6 have different p/s part numbers. different bypass ports.
http://www.amainhobbies.com/product_...ton-Sleeve-Set
alexrckid is offline
