Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
The New Werks B5 .21 Racing Engine >
Like Tree63Likes
Old 08-15-2011 | 06:50 PM
  #7546
blktransam's Avatar
take it out of the car fill up the sink or a large bowl/bucket and plug the fuel line with a screw or ur finger and blow into the psi line and see if bubbles come out anywhere hence a leak
blktransam is offline
Old 08-15-2011 | 11:40 PM
  #7547
Default B5 pro Arrived, but one small issue
After a long 2 week wait my B5 pro and 2013 finally arrived in Australia.
Cant wait to get this motor broken in.
But i found an issue with the motor crank/drive shaft has gone rusty on the end, and has prob pitted.
Is this going to cause any long term problems or do i just sand/wire brush the rust off.
It was most disappointing to see my new pride and joy arrive in not so pristine cond.
Do i need to pull the motor down and look for any internal corrosion?
The motor is still sealed in it original packaging.
I'm not having a shot at Ron as the main reason I purchased a werks was because of the amazing customer support he offers.
tried to post some pics but didnt work
http://www.flickr.com/photos/66494641@N08/6048800188/
sbv20j is offline
Old 08-16-2011 | 08:41 AM
  #7548
aptyk88's Avatar
i would just wire brush it off, mine too was a little rusty there
aptyk88 is offline
Old 08-16-2011 | 05:28 PM
  #7549
SEF's Avatar
SEF
Those pics could be a little deceiving, but it looks to me that the rust on the end is more than just something superficial that you can wire brush off.
Could be wrong though since the pics aren't the clearest.
SEF is offline
Old 08-16-2011 | 05:33 PM
  #7550
I ordered my new B5 engine and it will get here Thursday. I had a question about the pipe I will be running on it. I see most people are running a 2013 on it. I eventually plan on getting one, but my budget will not allow me to get one immediately. So for now, I will be running the JP-1 from Jammin that I have on my stock Losi 454 now. It's a brand new pipe with barely 5 tanks ran thru it. From what I understand, the JP1 is tuned to improve low end performance. Does anyone have any personal experience with this combo, or give me some idea how this pipe on a B5 will affect it's tuning and performance characteristics? I just don't wanna go into this combo completely blind, so I will be able to identify tuning issues with this specific pipe on the B5 and know if a problem occurs, or that's just how the engine should act with this pipe on it. Any info will be greatly appreciated! Thanks guys!
Chad
xlrsd is offline
Old 08-16-2011 | 05:44 PM
  #7551
Maximo's Avatar
Chad
it actually doesn't run too bad on a JP-1.....seems to be plenty snappy on the bottom and have a decent RPM range....It is definitely not as strong and crispy as a 2013, but it still does quite good...
Maximo is offline
Old 08-16-2011 | 05:57 PM
  #7552
Default pics
sorry about the pic clarity I didnt want to take the motor out of the sealed bag just in case it was something drastic
sbv20j is offline
Old 08-16-2011 | 06:15 PM
  #7553
151 RACN's Avatar
Chad
ha bud, if my cents is worth anything to ya, i run this same combo b5, jp1. awsome, i lke this combo, you should not have any problems with this setup. one thing about this sport is that, what works for one guys driven style
does not work for another guy. setups are the samething, i also have 2013 cause fellow racers said 2013 is the pipe to run, but for me jp1, i lke lots crispy bottom. sometimes its all in your finger on the trigger. you might have to lightn up in the clutch springs/ shoes. i also run losi truggy/buggy 2.0, both cars same b5 / jp1 pipe. bottom line to sport you have to be smooth on the finger. oh ya truggy 10 to 12 min run time /buggy some tracks 9 to 11 min. like i said before , train yourself to be smooth with trigger finger. one more thing, alum. pipes not the coated one ther is a diffrence in temps ,from to other
151 RACN is offline
Old 08-16-2011 | 06:55 PM
  #7554
Maximo and 151 RCN,
Thanks guys, that is actually very good to hear! I love a great bottom end, even if it takes a little from the top! The track I run at has a bunch of large jumps right out of turns, so a snappy bottom is exactly what I look for foremost! The only place you really open up the throttle for more than a second is the one straightaway! Cool. Yeah, I think I will definately have to manipulate the trigger a lot softer than I am used to going from the Losi 454 to the B5. I think it will be a great upgrade to my truggy. Thanks guys! Two more days until I get to start breaking that bad boy in!!
Chad
xlrsd is offline
Old 08-16-2011 | 08:22 PM
  #7555
hdcruzer's Avatar
Thats more than superficial, Id send it back...........
hdcruzer is offline
Old 08-16-2011 | 09:19 PM
  #7556
sbv20j, it's hard to tell by looking at that picture what is going on so I'm not going to jump to conclusion like Mr Cruzer above. If you would please just clean up the tip of the crank and if there are any issues I'll take care of you.
Regards,
Ron
Werks is offline
  #7557
Default Losi 8T 2 Optional Part
Quick question, can someone tell me what the part number is for the part that Losi came out with to ensure you get a better pull angle on your carb? I have ground my top diff plate down already to get a straighter pull, but it seems there may be a part out there to that will help.
SDelaney is offline
Old 08-16-2011 | 09:26 PM
  #7558
Muggydude's Avatar
just search "losi split center diff" on google
Muggydude is offline
Old 08-16-2011 | 10:02 PM
  #7559
Default pic
Thanks Ron I will remove it from its packaging tonight when I get home and clean up the shaft.
I was hesitant to clean it up before in case it created warranty/return issues.
I will keep you posted on the results.
Cheers
Simon
Regards,
Ron
sbv20j is offline
Old 08-16-2011 | 10:31 PM
  #7560
Cheers
Simon
No worries, anyone that has dealt with me knows that I'm pretty easy to deal with on stuff like this.
Werks is offline
