Like Tree6Likes
Team Orion Engines
Old 08-08-2011 | 12:15 PM
  #961
Yep 2013 just ordered will tty it out again this weekend
jewn_beef is offline
Old 08-08-2011 | 06:51 PM
  #962
Ultraspeed84's Avatar
just order the discovery motor was curious does it come with the restrictors 6mm 7mm 8mm? is this motor pretty crazy on bottom end power? or is it kinda like the 3port model where its pretty good bottom and very smooth transitions through out the power band? And what kind of run time people seeing with 2058 pipe or 2013s? Ive been running p5xlt houston tuned hoping to goto something with a little less bottom end!
Ultraspeed84 is offline
Old 08-08-2011 | 07:39 PM
  #963
Just ran mine last weekend on a pretty good size track in practice (yes it was practice but obese driving like it was the A main) I pulled 10:40 with the 2013 in a kyosho mp9 tki2. This motor so far is pretty basses. Can't wait to see what it will do once I get more fuel through it
skoalisbad4me is offline
Old 08-08-2011 | 08:02 PM
  #964
10;40 with 2013 so a 2058 should get a little better if im correct so i should be good to go. how was the bottom end and what else would u compare the bottom end to??
Old 08-08-2011 | 09:12 PM
  #965
v6shooter's Avatar
Originally Posted by v6shooter
I would say that it has one great attribute.That it is very balanced.Lowend,midrange,topend very ,very good.Does not do anything great.It does everything well
about 10 mins to 10:50 mins on a med track size jp3 [gas hog] pipe. Im sure it runs even better on a 2013,2057,and a 2058.btw 2013 pipe kicks a*s
v6shooter is offline
Old 08-08-2011 | 10:08 PM
  #966
Bottom end was still crazy sluggish so I can't even compare it to anything. Motor has right about a gallon on it so I am just now putting a full race tune on it. But I ran against one (same motor same car) and his bottom end was super crisp and poppy way snappier than an OS
Old 08-09-2011 | 05:37 AM
  #967
ScottyM's Avatar
Bottom end when tuned correctly is very snappy. Not super powerful but it will light the tires on command if that is what you want it to do. Or blip the throttle a tad and it'll transition to mid/high nice and quick.. It doesn't have the bottom end of the CRF 3-ports, but it has plenty, IMO..
ScottyM is offline
Old 08-09-2011 | 06:51 AM
  #968
Just so I can see how close I am, where should the bottom end be at? More or less of course
Old 08-09-2011 | 10:38 AM
  #969
yeah im not really trying to find a motor with a crap ton of bottom! I bought one of the standard head button orion 3 ports and that thing lasted me 6 gallons and it was only 155.00 new loved it very smooth predictable motor.. And easy to tune after putting the CRF carb on.
Old 08-09-2011 | 02:45 PM
  #970
ScottyM's Avatar
About 1.5 - 2 turns in from flush If I remember right. I've adjusted in small increments all summer long, slowly sneaking up on it, and I honestly can't say 100% if that is correct, but it'll get you fairly close..
Best way to know for sure is set .5-.7mm idle gap, tune the low end for good idle.. Take out on track tune the top end for speed and good smoke, bring in and reset/recheck idle. If you have to lean the top much you will probably have to richen the bottom an hour or two..
ScottyM is offline
Old 08-12-2011 | 11:20 AM
  #971
ScottyM's Avatar
How are those Orion Alphas running Boys and Girls?? Must be good no one is asking about help.. LOL
ScottyM is offline
Old 08-12-2011 | 05:16 PM
  #972
Headed to the track tomorrow to get a little more fuel in it and hopefully get the bottom end a little closer. Then Monday it's off to the engine guru to get a little mod work done
Old 08-12-2011 | 05:54 PM
  #973
Running mine in now. So easy!! So far I'm impressed.
ratjayfala is offline
Old 08-12-2011 | 06:32 PM
  #974
Stewie's Avatar
just ordered a discovery to replace my us spec. looking forward to breaking it in next weekend.
Stewie is offline
Old 08-13-2011 | 03:27 AM
  #975
setanborneo's Avatar
good choice
setanborneo is offline
