Like Tree5Likes
SC10 4x4 Thread
Old 08-05-2011 | 05:21 AM
  #5746
Default Tires
Bumpy...the V2 Calibers are working really well...they keep my truck hooked up in the hard pack/dusty/loamy mixed condition tracks here in Wyoming. Just dont get the M4 or they will be finished in a race day.
Guns is offline
Old 08-05-2011 | 07:54 AM
  #5747
Racecrafter's Avatar
Originally Posted by Bumpy
Well to start with we dont race indoors over here in NZ. Its mainly outdoors on loose loamy clay. I was thinking Goosebumps but would anything else work. Dont really want to go out and buy lots of different sets of tires to find only 1 or 2 types work the best.
My favorite loamy "go to" tire is the City Block. Once the track gets some runs on it if there is any hard to semi hard pack underneath the loam I will swith to Grid Irons.
(And Rebars work outdoors on hard pack/ light dust conditions wet or dry)
Racecrafter is offline
Old 08-05-2011 | 07:56 AM
  #5748
Originally Posted by Cameron Kellogg
Yeah maybe AE will make the FT version with carbon plastic.
Umm the stock chassis is carbon.
Old 08-05-2011 | 08:37 AM
  #5749
The stock chassis is fiber reinforced, but it's not carbon. It's similar to he b/t4.1 chassis.
Krio is offline
Old 08-05-2011 | 08:55 AM
  #5750
umm winning's Avatar
I like to run subcultures for outdoors but ive heard that gridirons are good to
umm winning is offline
Old 08-05-2011 | 09:04 AM
  #5751
AKA enduros
bohdi is offline
Old 08-05-2011 | 09:36 AM
  #5752
BlueGlowBoy's Avatar
I like the enduros for our big outdoor track. I would like to think that it would be considered rough, medium bite clay. It's been so dry around here lately that it's almost impossible to keep any moisture in the track, even if it's flooded the day before a race...
Right now I'm running the hardest compound, since the track is so abbrasive... I might grab some slightly softer ones for the RCPS Canadian Nationals here in September.... it will be cooler out by then (I hope!)
BlueGlowBoy is offline
Old 08-05-2011 | 09:38 AM
  #5753
Default Diffs?
Is anyone wearing out front tires faster then the rears? It seems every time I punch it down the straits my fronts are ballooned and wearing out way too fast. I have considered going to a 3000wt diff fluid in the front but is this going to be the cure?
Guns is offline
Old 08-05-2011 | 09:49 AM
  #5754
Cain's Avatar
do you mean 30K?
Cain is offline
Old 08-05-2011 | 10:09 AM
  #5755
Speaking of Diff oils, I've been running 10k front and rear ( AE 5k was out of stock and thought 3k might be too light). Do you guys recommend going with 3k in the rear? what are the effects of running lighter wt in the rear?
GuiltyByAssoc is online now
Old 08-05-2011 | 10:10 AM
  #5756
Jstall7543's Avatar
My best advice to you would to see what the fast guys are running and talk to them or the track owner, my local track owner only sells tires that really hook on his track. It's hard for anyone to say without being there.
Jstall7543 is offline
Old 08-05-2011 | 10:14 AM
  #5757
Yea...typing on my phone sucks...it was a suggestion from one of the guys at the track, is it going to be too much?
Guns is offline
Old 08-05-2011 | 10:16 AM
  #5758
T-BirdJunkie's Avatar
This sounds to ThunderbirdJunkie like the front end unloading and the center diff diffing out.
Unfortunately, we don't have center diffs.
It sounds like the slipper is slipping on the outer pad but not the inner pad, diff oil won't fix this.
That being said, ThunderbirdJunkie is running 20k in his front diff if he recalls correctly.
T-BirdJunkie is offline
Old 08-05-2011 | 10:23 AM
  #5759
Jstall7543's Avatar
Are you running the overdrive pulley? I'm running 5000 in both diffs, no ballooning, 20t on both pulleys. What tires are you running and what compound? They maybe to soft for the power your putting down. I like all my cars to have a even all wheel drive feel to them, that works best for me. Check your slipper pads.
Old 08-05-2011 | 12:37 PM
  #5760
I'm running the 19th in the front which I'm sure has something to do with it but if possible want to stay with it, I like how the truck feels with it. I'm running M3 calibers. The slipper is locked down and after every raceday I rough up the pads with sand paper. They look pretty glazed before I sand them though.
Guns is offline
