2 stage pistons...Do they work? >
Old 08-03-2011 | 08:34 AM
  #151
Coppercanyon's Avatar
Marcus, Did you already ship the Caster pistons?, ordered them on Wed. 27th.
Coppercanyon is offline
Old 08-03-2011 | 08:35 AM
  #152
MantisWorx's Avatar
Originally Posted by Buzz3
Any timeframe on the SCTE losi pistons yet? Thanks
someone was supposed to send me a shock to measure but i havent recieved it yet so i can not give you an ETA just yet, will let you know when they are in my hand.
Stealth if the pistons are 16mm than they are the same piston as the RC8! let me know on an exact measurement you may be in luck!
MantisWorx is offline
Old 08-03-2011 | 08:37 AM
  #153
MantisWorx's Avatar
i did not get to the track til last night, i have a setup for them so will machine them late tonight and ship tomorrow. i didnt want to to give you a set of blank pistons without some testing to at least get you in the ballpark. i will ship them out priority tomorrow. they work very nice!
Old 08-03-2011 | 08:42 AM
  #154
Were you at the track after hours? I was there at 6pm but no one was running. I'll be there again this afternoon for a little while.
fredswain is offline
Old 08-03-2011 | 08:46 AM
  #155
MantisWorx's Avatar
i was at katyrc
Old 08-03-2011 | 09:10 AM
  #156
larlev's Avatar
Originally Posted by MantisWorx
i was at katyrc
Track looks great...been following on rcfiles. We will have one soon in Austin
larlev is offline
Old 08-03-2011 | 10:44 AM
  #157
Buzz3's Avatar
I hope so but if that group of misfits doesn't learn to quit eating their young it may never happen... That's why the best outdoor track in Austin is in someones backyard right now. Total control.
Mantis, the Losi are 12mm. Is there any measurements that we can give you to help make it happen? Thanks for your help.
Buzz3 is offline
Old 08-03-2011 | 11:34 AM
  #158
When the Serpent pistons were in short supply, I used Kyosho 16mm big bore pistons with success. Just had to drill out the center mounting hole to 3mm. But I will get you exact measurements after work today.
Stealth_RT is offline
Old 08-03-2011 | 11:42 AM
  #159
When you check your rebound on the bench by pressing down on the car and then releasing to see if the front and rear rebound equally are you also setting the preload on your shock springs the same front to rear? It seems as if you have them set differently that the spring pressure is going to dictate how fast they rebound.
Old 08-03-2011 | 11:49 AM
  #160
Any news on Losi XXXSCT getting these?
Error404 is offline
Old 08-03-2011 | 12:05 PM
  #161
Several things affect rebound rate such as spring rates, shock oil, and pistons.
Old 08-03-2011 | 03:18 PM
  #162
larlev's Avatar
All I can say is your right.....it is a shame isn't it?
Karma is a bitch....lol
larlev is offline
Old 08-03-2011 | 04:43 PM
  #163
Confirmed that Serpent S811 pistons are 16mm, with a 3mm center hole, and piston is about 2.4mm thick at the mounting hole.
Old 08-03-2011 | 04:45 PM
  #164
im going to go more into this on the site but i know you are chomping at the bits!!
go bigger holes in the rear right off the bat (1.2/1.3) and stay with the 30 wt. the frt and R should feel about the same. if you compress the chassis all the way down and release they should both come up at the same time. Shoot for 30/35 wt so that when you change tracks you should only need to change oils to match. so you dont want to set your truck up with 25wt because you dont really have anywhere to go lower (20 is too thin for anything). on the front sounds like you may want to go to 35wt. Soooooo
Front 35wt 1.1/1.2
Rear 30wt 1.2/1.3
try it and let us know how it feels
Rebuilt the shocks tonight and changed to what you suggested, and it feels really good on the bench. Can't wait to try it on the track.
Old 08-03-2011 | 04:59 PM
  #165
MantisWorx's Avatar
how are the pistons held down? nut or screw?
Stealth-looking fwd to your results!
