Like Tree5Likes
SC10 4x4 Thread
Old 07-28-2011 | 04:05 PM
  #5416
MiDGet's Avatar
i think im about 2/3 of the way thru the build of mine atm.
it is by far one of the easiest builds ive ever done!
MiDGet is offline
Old 07-28-2011 | 04:27 PM
  #5417
Wild Cherry's Avatar
Originally Posted by Robotech
2 ways. One, he said the wire connectors are not air tight...thus they are not Water Vapor tight either. Air contains water vapor. Second, the motor, if it was completely air tight, is not made in a vacuum. Thus there is already air, with water vapor, inside when it's built/rebuilt.
Not making an argument for either style, just answering your question.
As for how it condenses inside the can...I'm willing to bet that it has more to do with the cooling of the motor after a run then while it is actually operating. If you're running in a high humidity environment there will be more water vapor in the air. As you run your motor the temperature of the motor increases until it is (hopefully) in the mid 150 range. When you're done running, the motor will cool off as now the ambiant air temp is only 70-90 degrees. The water vapor inside may condense on the inside of the can just like it does on the outside of a glass with a cold beverage in it. Since no electricity is moving through the motor the water won't bother it.
Like I told my son, water and electronic devices are fine together, its water and ELECTRICITY that don't play well. Remove either from the electronic device in question and you don't have an issue.
Never had a vented can get the water issues .
Every seal can I have purchased ?
Open can right after running and I will show you the water on the sensor board and end bell cover....
Wild Cherry is offline
Old 07-28-2011 | 04:42 PM
  #5418
CentralCoaster's Avatar
I considered this, but even if the temperature changes in the can, the dewpoint of the air does not. So it will heat up, and cool down, and still be above dewpoint the entire time. Hot air CAN hold more moisture, but there is nothing adding moisture.
If he has water in his motor, then he has water in it. I'm not sure how its getting in there, and so I'm not sure if everyone else should expect the same. I'm stumped.
CentralCoaster is offline
Old 07-28-2011 | 05:08 PM
  #5419
Mac The Knife's Avatar
I'd be suspecting his pitmates,,,, And is it really condensation? or are they taking advantage of his motor while he is turn marshaling.
Mac The Knife is offline
Old 07-28-2011 | 05:19 PM
  #5420
Back when CentralCoaster used to refer to himself in third person, CentralCoaster discovered fellow racers were dunking CentralCoaster's rc car in the tire sink while CentralCoaster was turnmarshalling.
Old 07-28-2011 | 05:21 PM
  #5421
id rather swap battery bullets to fry a competitor's esc than get messy with water.
shadoflame is offline
Old 07-28-2011 | 05:36 PM
  #5422
Jstall7543's Avatar
Back to the SC10 4X4 please!
Jstall7543 is offline
Old 07-28-2011 | 05:44 PM
  #5423
Vegatron75's Avatar
2 funny, that reaks of TBJ!!!
Vegatron75 is offline
Old 07-28-2011 | 05:48 PM
  #5424
Default thinking of getting a sc10 4x4
i was thinking of getting a sc10 4x4 soon. I was just wondering what problems people have had driving them and if i should wait till the bugs are worked out if any. I talked to some people that drove them and got mixed feedback. I did try one for about 10 min. and it was very easy to dirve compared to 4x4 slash i had. Even had better lap times not even trying so any info will help thanks.
cheeks8 is offline
Old 07-28-2011 | 06:16 PM
  #5425
Originally Posted by JayL
JayL thinks Mac the Knife has crazy FAST Service
Yellow Front Springs on the way, can't wait to feel the difference
I'll get to see how fast his service is tomorrow as i'll be ordering a basket!
teesea is offline
Old 07-28-2011 | 06:22 PM
  #5426
I have had mine for a week now and on the track 3 times for practice. I just got factory spring kit and sway bars f/r today. Sway bars make a difference in traction rolling. I love my sc10 4x4....no regrets, durable, fast and handles amazing. Im running suburbs and calibers on mine and they seem to work well. There are no bugs with my truck, and havent had an issue with it yet.
barry1me is offline
Old 07-28-2011 | 06:23 PM
  #5427
Originally Posted by teesea
I'll get to see how fast his service tomorrow as i'll be ordering a basket!
Operators are standing by.
Old 07-28-2011 | 06:28 PM
  #5428
Jstall7543's Avatar
I just picked mine up a few weeks ago, it's been amazing! I also own a bce chassis losi carbon and Ti everything, the losi is very good but where I run I'm faster with the stock sc104x with less motor and smaller batteries. No special mods are required IMO except the tires that work best at your track. I just did my basic setup on it, mostly to the book and it's rediculous out there! Nothing has broke yet and I've put it to the test!
You should drive the Losi and then decide.
Since I got the sc10 I havnt felt like driving the losi. Lol! Before that I loved the losi, I put over $400 in mods on it, spared no expense.
Everyone is different but I can tell you all the SC truck have their issues when put to the test.
People keep having belt getting pinched between the front pulley problems, then you roll the truck backwards to un bind it. Happen to me twice in 15 batteries after lawn darting into the face of a quad over shooting a triple. I'm running both 19t belt pulleys so my belt is looser I think.
Hope this helps.
Old 07-28-2011 | 06:46 PM
  #5429
First time my sc10 4x4 did a wheelie down the straight, Thanks, well worth it.
sbales is offline
Old 07-28-2011 | 07:22 PM
  #5430
Jstall7543's Avatar
Funny stuff!
