SC10 4x4 Thread
#4096
Need some advice on how to get the ballstud pushed through linkages.
Its feels as if I would break the linkage if I tried to force it on to the ball stud.
I was able to get the ballstud over the servo horn stud, but it took alot of pressure (bearing down very hard pushing down on it resting on a table)
Any tips/tricks to this?
Thanks in advance for any help.
#4097
#4098
You can get them in 52, 54, and 56t flavors if ThunderbirdJunkie recalls correctly.
He will consult the packages his spurs came in and correct this post accordingly.
#4099
I raced at west coast today. I used Cavs set up & the truck was a night & day difference with the front & rear sway bars! I qualified 3rd overall but blew it in the main & finished 5th. I'm looking forward to putting more & more battery packs through the truck!
#4100
#4101
Hey TBJ I was wondering, I am running a mmp w/ tekin 5.5 sc4x motor, I only have a 16t pinion for now, what size spur should I go with? Or is 16t just to much? Thanks
#4102
BTW...did you see the top secret stuff over at NC?
#4103
#4104
Well I just thought 16t was to much and would cause overheating, I ran it with the 16t/62p last week at the indoor track and after about 4-5 laps it was tempted around 160 I believe, so I'm thinking maybe if I drop the spur down to say a 56 I should be fine...... Oh and I'll check out NC after this
#4105
Nah I run at Coyote Hobbies in Victorville....... I'm going to try dropping down to a smaller spur to see what happens. I did buy a 12t pinion but it hasn't came in yet........
#4106
If you're not looking to gear higher (IE bigger pinion) then the bigger spur gears aren't in your cards...but they do allow more finite gear ratio adjustment.
#4107
I am very satisfied with mine. I bought it Tuesday, had it completely assembled on Thursday. I ran two packs through it Friday to shake it loose then went to the local club race Saturday. Qualified 3rd with fastest lap and finished 4th, good for me! With a little more consistency I am in the top 3!
Very happy, our track is a big 1/8 style track but the 4x4s run hard and fast on it. Props to the Castle 1410 and MMP, hung in there nicely with all the big 550 cans.
#4108
Going to a smaller spur gear is like going to a bigger pinion...it will make the truck faster. I don't know how big coyote is, just watch your temps.
#4109
Has anyone had any experience running this truck with the new Tekin, LRP or Novak 4.5T 550 motors that have been developed for this class..?
Just wanting to hear your feedback before i make a decision on which one to go with...
#4110
5Likes
