HELP for the MT12
Old 05-30-2004 | 10:00 PM
Techart27's Avatar
Default HELP for the MT12
Anyone have their HSN carb setting for their MT12 (Novarossi RS12) or know the factory setting. I totally ruins my setting when moving the fuel intake so i need to know roughly how many turns to backout the HSN so i can start turning from there again. Thanks
Techart27 is offline
Old 05-30-2004 | 10:27 PM
fmolzer's Avatar
Start at about 4-4.5 full turns out.
fmolzer is offline
Old 05-31-2004 | 07:25 PM
Techart27's Avatar
ok ill give that a try
thanks
Old 05-31-2004 | 08:51 PM
Tag's Avatar
Tag
don't forget on the low end start with 3 1/2 turn
Tag is offline
Old 06-01-2004 | 03:57 PM
Techart27's Avatar
Ill keep that in mind but luckily i didnt change the low end setting when i adjusted the fuel intake
Old 06-04-2004 | 03:32 PM
nitro rookie's Avatar
Factory settings are 4 1/2 on top and 3 1/2 on the bottom mid should be flush.
Good luck
nitro rookie is offline
Old 06-04-2004 | 05:21 PM
Techart27's Avatar
thanks alot
Old 06-11-2004 | 07:15 AM
spyspeed's Avatar
Try 4 on HSN and 2 1/2 on LSN and mid Turn in 1/4 from flush.
Use 25%Nitro with 0.2 Head Shim and Nova no:5 Hot Glow Plug. My engine Temperature was 198F.
Try it.....
spyspeed is offline
