HELP for the MT12
Anyone have their HSN carb setting for their MT12 (Novarossi RS12) or know the factory setting. I totally ruins my setting when moving the fuel intake so i need to know roughly how many turns to backout the HSN so i can start turning from there again. Thanks
Start at about 4-4.5 full turns out.
ok ill give that a try
thanks |
don't forget on the low end start with 3 1/2 turn ;)
Ill keep that in mind but luckily i didnt change the low end setting when i adjusted the fuel intake
Factory settings are 4 1/2 on top and 3 1/2 on the bottom mid should be flush.
Good luck |
thanks alot
Try 4 on HSN and 2 1/2 on LSN and mid Turn in 1/4 from flush.
Use 25%Nitro with 0.2 Head Shim and Nova no:5 Hot Glow Plug. My engine Temperature was 198F. Try it..... |
| All times are GMT -7. It is currently 07:34 PM. |
