Old 06-10-2004, 04:07 PM   #1
jjmudd's Avatar
Default Glow Plugs
This thread is for plug related questions. Here is mine!!
What would be causing the plugs in my .12 engine to be pushed up and in, as if someone had taken a small allen wrench and pushed the coil up? Also looks as if small ball of metal (thrust bearing sized) is melted to the coil. The motor never gets above 240 degrees and smokes nicely on initial throtle. It runs for two minutes perfectly and then poof, the plug self destructs. All types of plug are affected, MC-59, O'Donnel 77, O.S.8...etc. Any ideas??
jjmudd is offline   Reply With Quote
Old 06-10-2004, 04:41 PM   #2
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: Glow Plugs
May be the motor is over compressed, check your headshims
Ah10 is offline   Reply With Quote
Old 06-10-2004, 04:52 PM   #3
ade
ade's Avatar
Trader Rating: 22 (100%+)
This happened to me also. I found that my engines cylinder had too much fuel in it and my heat adjustable ignitor was a little too high. When the engine was flooded and I put the ignitor on to start the engine would continue to turn over but not start check the plug and it was blown- looked like a small ball on the end of the plug.
Make sure your engine is not getting too much gas and your ignitor has enough heat - not too much.
Hope this helps.
Tony
ps - I went through 5 plugs before I figured this out. got the engine running again and adjusted my needle settings.
ade is offline   Reply With Quote
Old 06-10-2004, 05:10 PM   #4
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default bLOWN PLUGS
I agree with ah10, too much compression! What percent fuel are you runing? Most engines come pre shimed for up to 25% nitro, if you are runing 30% put in a 0.10 mm shim and try again. If you are runing 30% go to a warm plug not hot, especially if you have a long straight ( over 180ft).
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 06-10-2004, 05:58 PM   #5
jjmudd's Avatar
Slotmachine,
Send me an e-mail about the Palmaris motor please. I have one on order and would like your take on this mill and best break in procedures for it. I would appreciate it.
Thanks,
John Hughes, [email protected]
Old 06-10-2004, 06:07 PM   #6
EdwardN's Avatar
Slotmachine,
Thanks,
I would probably helpfull on it too. I am little bit familiar with that mill.
There is no break in procedure in normal understanding of that word. you will just need to run on starter box one tank 30% open throtlle very reach ( 190 F) and then one tanks low reach around the track and it is ready to go.
At list I use this procedure when I got mines.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 06-10-2004, 09:18 PM   #7
C Verano's Avatar
You should check the bushings in the rod.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 06-11-2004, 01:15 PM   #8
jjmudd's Avatar
Thanks for all the help guys. I'm going to pull the motor apart today. I'll check the bushings first and then the shim hight and then use it as a paper weight!!
Glow Plugs ? Fuzzchop Nitro Off-Road 1 04-13-2008 05:42 PM
glow plugs 32819toon Nitro On-Road 2 03-21-2007 01:33 AM
Nitro accessories needed: Glow Plugs, Glow Ignitor, Temp Gun Cain R/C Items: Wanted to Buy 8 07-05-2006 06:22 PM
Glow plugs John Troxel MARCCA Discussion 2 07-27-2005 08:43 PM
Will a standard glow ignitor work on a turbo glow plugs? Ducati998 Nitro On-Road 3 01-20-2003 12:54 AM
