RC10B4.1 FT/WC
Old 06-11-2011 | 09:18 PM
  #3136
SPN
I agree on the wiring!
Wanted to give some folks here a heads up. I am looking to thin down the b4 herd.
I would like to keep 2 B4's only.
Looking to get rid of
1 FT B4.1
3 FT B4 with .1 upgrades and 2 of them could be completely converted to 4.1's
1 B4.1
Also selling a T4 not FT
Each buggy has various mods such as aluminum inline axles, Lunsford turnbuckles, etc. They all have CVD's and everything is in good to excellent shape.
I also have some speed control, motor, servo combos to get someone fully operational on the high end or on the budget.
Carey
PM if you're interested.
Here they are in the hobby room (cropped to avoid the chaos)
SPN is offline
Old 06-11-2011 | 10:32 PM
  #3137
rcjoe99's Avatar
ok i have a bit of a problem i got used t4 from guy the track for good price but the thing is the front axles are hex connecters and they are striped out... so how do i get them off and what will want to replace i want to keep the hex connecters just what is the replacement part for it how do i take it off
will the b4 axles work or no
http://www.losipartshouse.com/servle...-Center/Detail
rcjoe99 is offline
Old 06-11-2011 | 11:04 PM
  #3138
T&D-RACING's Avatar
Thumbs down
I don't know if the b4 axles would hold up to the bigger wheels of the t4.
T&D-RACING is offline
Old 06-11-2011 | 11:45 PM
  #3139
rcjoe99's Avatar
what about these http://www.losipartshouse.com/servle...ng-cln-/Detail
but are they the ones with the hex connecters
rcjoe99 is offline
Old 06-11-2011 | 11:55 PM
  #3140
T&D-RACING's Avatar
I don't know what you mean by hex connecters.
Old 06-12-2011 | 12:36 AM
  #3141
ruf's Avatar
ruf
Originally Posted by t0p_sh0tta
Does anyone know where the Kyosho big bore springs fit into this chart?
Biff - Welcome back!
ruf is offline
Old 06-12-2011 | 01:17 AM
  #3142
sounds like they may have done the losi conversion on it if it has hex's can you post up a pic?
kryne76 is offline
Old 06-12-2011 | 05:07 AM
  #3143
Originally Posted by Justin R
alright I've just about had enough with my transmisions.. I cant take the noise anymore
I have a FT B4.1 and a FT SC10. The transmissions are quiet when I spin them on thier own but the minute I put a pinion to them they get noisy.... yes the mesh is checked. not too tight and not loose. A piece of paper could fit in between. I'm using regular Robinson Racing pinions and AE spur gears.
any ideas ?
Give these a try. Takes care of the egg shaped spur gears as I like to call them. 75,78,81,87 No 84 yet I'm trying to talk them into it. lol
http://www.teamepiconline.com/shop/i...p?item=TEP4281
DHMOTORSPORTS is offline
Old 06-12-2011 | 06:40 AM
  #3144
My B4.1 RTR has arrived, its a fast little beast!! do have an issue thou..
Whenever the car hits something hard (which is often the way I drive), the steering servo will shutdown by itself and I can no longer steer. However, if I touch the connector from the servor to the receiver the servo will sort of reset itself and I'll get steering back again.
Do I have a servo issue? or a lose connector issue?
thx!
GuiltyByAssoc is offline
Old 06-12-2011 | 07:52 AM
  #3145
ffiB's Avatar
Hey Joe! Whats up brotherman? You running 10th scale now? Look me up when you come back into town.
ffiB is offline
Old 06-12-2011 | 09:22 AM
  #3146
rcjoe99's Avatar
heres the pic of it what is the replacement part for it
Attached Thumbnails RC10B4.1 FT/WC-044.jpg   RC10B4.1 FT/WC-041.jpg
rcjoe99 is offline
Old 06-12-2011 | 09:59 AM
  #3147
Matt Trimmings's Avatar
Looks like it may have these:
http://www.amainhobbies.com/product_...-Front-Axles-2
Should have these:
http://www.amainhobbies.com/product_...-Trailing-T4-2
Could also have these, but they were made for the b4 and sc10...not the t4:
http://www.amainhobbies.com/product_...ont-Axle-Set-2
Matt Trimmings is offline
Old 06-12-2011 | 10:10 AM
  #3148
rcjoe99's Avatar
Should have these:
thanks man would blue ft team ones work for the b4 or no are they less durable sence there made for the b4
rcjoe99 is offline
Old 06-12-2011 | 10:15 AM
  #3149
The blue ones are made for the b4. The offset is different between the buggy and the truck. The ones you want are the steel black ones in the link posted above or I believe Lunsford sells some titanium axles. Just search throgh what Amain has and if you have any more questions just post them here.
Old 06-12-2011 | 10:22 AM
  #3150
Cpt.America's Avatar
From what I understand, kyosho hasn't released the spring rates of their big bores at all... they call them "soft", "medium", etc.... somebody would either need to do the finger squeeze test, or an actual independent spring rate test.
Cpt.America is offline
