Team Associated RC8Be Thread
#6286
#6287
I recently converted my rc8b to electric. I am looking at getting a new charger and I am needing to be able to charge both a reedy 5500 4s and a reedy 5000 2s on race day. Looking on suggestions for good chargers. I am looking to stay within around 260 with charger and power supply.
#6288
http://epbuddy.com/index.php?main_pa...&products_id=3
http://epbuddy.com/index.php?main_pa...products_id=13
You should also purchase an extension for the balancing wire:
4s: http://epbuddy.com/index.php?main_pa...roducts_id=125
2s: http://epbuddy.com/index.php?main_pa...roducts_id=123
This charger will charge all sizes of LIPO's. It has outstanding built in safety cut off's (not to say you should leave it unattended). They ship the fastest out of any hobby dealer I've dealt with to date.
That's my $0.02.
Oh, and the functionality is easy
#6289
Can normally be had for around 120-130 bucks too so its priced rather well.
#6290
I like this charger best. Have been using it since last yr, no problems easy to use, see and does everything needed even to store your batteries.
http://www.hobbyking.com/hobbyking/s...idProduct=7386
Beware other chargers say they will charge up to 6c but they wont do it at full amps.
And I dont have one of these but if I bought a power supply this is the one I would get.
http://www.maxamps.com/Power-Supply-12V.htm
#6291
http://www.hobbypartz.com/75p-t6-multi-charger.html
and this power supply
http://www.hobbypartz.com/77p-g350-powersupply.html
I have been only using it for a couple months, but they are the same charger that most hobby shops are charging $149. for. Charge/balance 4 batteries at a time is priceless.
#6292
Fellow RC8be Owners:
I have started a thread titled, "Tuning with camber links". It has really taken off for suspension tuning. I'd strongly suggest taking a read from page 1 on. A nice gentleman by the name of "Fred" is one of the most knowledgeable I've seen regarding suspension / camber set up. It's really blowing up quick and with tons of great information. Many are retuning their cars (including myself) as we speak.
This thread has been going very well. I'd like to see it continue along those lines, but I'd also like to get specific in set up's with the RC8be. This thread is generalized for every RC out there because the principles are virturally the same all the way around, but we as RC8 owners do have differences with the weight of our car, balance points, etc... and I'd love to have that conversation bleed into more specifics into our cars as it goes along.
Feel free to check it out and maybe drop some input into this RC8be thread of how we can specifically make things apply to our set up's. Things that work / don't work.
#6293
#6295
I have drilled a hole in the bottom of the ESC tray (not the chassis plate!) en attached one side of the Traxxas Mamba Monster mount. Together with a big piece of waterproof double sided tape it is really solid.
#6297
Hey guys I just got an rc8be with a teckno v3 chassis, MMM 2200. I run on a high bite clay track (WCRC) I'm thinking of running soft suburbs tires, 45wt oil F&R, medium springs all around, diffs using a 5/7/5.
I know some go 3k oil on the back but I'm thinking with the V3 chassis it will give me better steering to where I can keep the power equal and not have a lot of push in the tight corners.
Anyone that runs at WCRC input would be appreciated. Thank you.
#6299
Still kinda waiting to hear back about shipment.
Lookin' forward to getting it though.
-David
#6300
Hi David check your EM you should have Updated ship info
Drop us aline back once you receive Also post some pics of your build
Here..Let us know if you need any set up help or advice
Thank you
