Like Tree5Likes
SC10 4x4 Thread
Old 05-26-2011 | 08:26 AM
  #2236
Jmuck69's Avatar
I have found that putting your truck or buggy in the dishwasher will remove the servo tape and clean all electronics completely.
Jmuck69 is offline
  #2237
bigs's Avatar
Originally Posted by Vegatron75
How many posts does it take to figure out the dang clicker? The manual makes it pretty clear, so I thought.
Jeez, What's next? How to remove double sided tape?
Because the manual said 3mm locked at 3mm the front tires still click. That tell me that the clicker is not locked.
bigs is offline
Old 05-26-2011 | 08:29 AM
  #2238
oven works too just make sure you put it on a baking sheet or it makes a little bit of a mess.
sand geek is offline
Old 05-26-2011 | 08:35 AM
  #2239
racer1812's Avatar
Super Moderator
can't rely on everything you read...
I do this all time, it works great. With CC foams I don't have to worry about taking my wheels/tires off so I don't wreck the foams anymore either.
racer1812 is offline
Old 05-26-2011 | 08:46 AM
  #2240
Arigato's Avatar
Are you sure it's the clicker and not a loose belt? I thought I had the same issue but tightened my belt and it went away.
Arigato is offline
Old 05-26-2011 | 08:47 AM
  #2241
Wild Cherry's Avatar
check that belt
Wild Cherry is offline
Old 05-26-2011 | 08:49 AM
  #2242
Cain's Avatar
Goo Gone works good too. spray, let it sit for about 5 minutes, wipe off.
And yes, I know you were being sarcastic.
Thanks for the info guys on the tires!
Cain is offline
Old 05-26-2011 | 09:21 AM
  #2243
Toiffel's Avatar
Never mind went back and checked, u r right.....
Toiffel is offline
Old 05-26-2011 | 09:23 AM
  #2244
Jmuck69's Avatar
I make chocolate chip cookies when i put mine in the oven to dry it off. CC foams add a certain flavor to the cookies.
Jmuck69 is offline
Old 05-26-2011 | 09:29 AM
  #2245
Aside from sending a (too long) shock tower screw through the front idler gear, this has been a pretty good build. Need to sort my screws better.
Cant wait to run it.
FlyByWire is offline
Old 05-26-2011 | 09:33 AM
  #2246
alexkenison's Avatar
has anyone tried running a tekin 540 motor with the 14mm hi torque rotor in it?
alexkenison is offline
Old 05-26-2011 | 09:34 AM
  #2247
What, are you going rock crawling Alex?
flame56mx is offline
Old 05-26-2011 | 09:42 AM
  #2248
just trying to get by with out buying another rx8 if i can help it. its hard to find your posts now dont have the sig or the pic im used to.
Old 05-26-2011 | 09:46 AM
  #2249
having trouble getting rebound in these shocks. Any tips ?
xxxtruck is offline
Old 05-26-2011 | 09:48 AM
  #2250
if your building it with bladders make sure that the bladder doesn't have a small tear... cost me nearly a full bottle of 25 weight before i caught it
