Speed Passion Thread
#121
If you like to change multiple motors very often, use the plugs. Otherwise, cut it and soldered to the motor tabs.
Yes...Speed Passion does sell 180mm and 250mm sensor wires...good enough for 1/8th off road.
#122
Stock Club Race esc does not have these option...it has no timing, strictly for the ROAR sportsman, no timing, USVTA type of class racing.
Both are great ESC..........
#124
#125
I used 528 mod with 7.5 in 2wd and 4wd for the past few months with most of the settings near the max without any problems. Its the last sc setting you want to tame down to -3 or so to keep motor temps in check. Especially in warmer weather. I used 23/78 geared in a b4 and 22/78 in a b44
Heard these ORCA motors have lots of grunt anyway so may flash back to 205.
I have a habbit of generating heat which is what I want to avoid.
#126
#128
I have both, but personally like the 2.1. All alum top half and all black look stealth.
Diff is 2.1 comes preloaded with supercharger software for Spec racing. 2.0 does not, both can be reflashed to run whatever you want with LCD card. 2.0 runs down to 3.5 motor and 2.1 handles down to 5.0 turn.
Amainhobbies has great deals both http://www.amainhobbies.com/product_...less-ESC-Black
http://www.amainhobbies.com/product_...C-Carbon-Black
#129
Didn't get to race this weekend but did get to spend a few hours at the track. Love the 205 Mod, pulls better out of the corners, a little more top than what I was running before, and brake feel is better. 6.5 temped 165 deg F after a hard 10 min run in B44, ambient temps were 92 deg, about all I can ask for.
212 Stock sofware is nails. I can't believe what you can get out of what passes for a "Stock" motor these days LOL. My B4 was absolute money for about 6 minutes, until the motor got above 150 deg and faded a little. Still pretty good even so, but the motor would come off after 10 minutes at about 155 to 160. Wouldn't care except it did fade a little at those temps. This is with a Trinity Nemesis 17.5, FDR 6.24, running the 212 Stock settings David posted on Pg. 1. Anybody have experience with that motor? Top end is not an issue, I could go down a tooth on the pinion if it will help motor temps. I have a 17.5 Duo 3 on the way, but would like to be able to use both motors if I can keep the Nemesis under 150.
#130
Hi
Thanks for the info, what settings really affect heat etc?
If I have been running a 6.5 V3 in 4wd, what motor would you go for based on the extra SC settings etc.
Regards,
Mike
Regards,
Mike
Mike
Get some blank setup sheets for 528
Write down the default settings for 528 mod as a referance. I would then start with Cockerill's 422 setup below as a base. You can compare the two. 422 is "hotter" and more aimed for stock so I believe settings should be pretty safe. Watch temps!
#132
Just a heads up on our previous discuission about running a 7.5 on the 2.0 pro without a fan in a 2wd buggy.. I ran the car as hard as I could till lipo cutoff, and temped the heatsink at 108 degrees.... the speedo is a tank.
#133
hey SP tech u guys ever run into a issue with the Cirtix SC master esc ?
last year i purchased one ... ran it 2 races then it poped and caught fire .... got it replaced an used it in my sc truck for the last 5 races of last season and worked mint ...and its no longer under warranty due to be purchased last year
today was first open practice day. 4 laps in it went pop again an caught fire in my sc10 again ...
sadly i cant say it was to a over timing ... issue cuz i was running it at 0 and on the motor 0 timing ... motor was 89 deg temp outside was only 62
my gearing was like 81/25 with a 17.5 d3 5000 40c 2cell lipo
thermo was on also .. and didnt shut off just just flamed
in no means am i bashing Speedpassion ... but just looking for some answers on this ... cuz i have suggested this esc combo to few friends and they have ordered em .. an i was also lookin to upgrade to the better speedpassion. u guys have been helpful ... so any kinda light to shine on this would be great .
Rob
Rob
#134
Attachment 745736
Rob
Attachment 745736
Rob
#135
As long as running in 2S, the GT2.1 works as good as GT2 PRO or other ESC in the market....with the new SC software that we are going to release soon, it has been killing on the track. We have drivers used it on SCTE 4x4 and it is the best ESC so far, smooth power and the brake is unbelievable. According from them.......
And yes...its been tested with NOVAK HV5.5. the new 550 and Tekin 550....all works. Just pick your choice of motor.
And Speed Passion will release our own 550 motor soon....our driver is testing it now. Both 4X4 and 1/8th....it is the best so far.
4Likes
