Like Tree1Likes
Messuring engine timings
Old 04-17-2011 | 12:16 PM
  #16
With new engines the brightness of the light does not matter much so far I have seen. the sharp edges of the ports and small tolerances is cutting the light as a sharp knive.
Indeed as you are mentioning I do have some small difficulties with rounded edges and the V-shape exhaust ports but indeed if you use a steady methode for it you will get far.
Roelof is online now
Old 04-17-2011 | 02:20 PM
  #17
I use a depth gauge and a known thickness stopper. 100% consistent.
xe
maxflo777 is offline
Old 04-18-2011 | 03:54 AM
  #18
This is the setup i use, I find it extremly accurate, i do find that the key to accuracy is using a dull light.
Attached Thumbnails Messuring engine timings-img_1541.jpg   Messuring engine timings-img_1542.jpg
mtmmotorcycles is offline
Old 04-19-2011 | 04:25 PM
  #19
ralphierace13's Avatar
? whats the down side if u raise the timing 1 degree and its not good what happens, i mean does it get slower, ruff idle, hard to tune do u loose bottom end or top or it just dont get faster... thanks
ralphierace13 is offline
