RC SCALE TANKS corner
#47
thanks mga sir!!
so far main drive gearbox pa lang at electronics ang naikabit ko, medyo malalaki kasi yung hardware na meron ako, pinagpalitan lang kasi ito ng Heng Long Tank which I upfraded to better electronics, kaya may spare ako..
Mahirap pag planuhan yung blade elevation and angle, malamang elevation na lang muna ang pagaganahin ko
will keep you posted here.
#48
I was able to secure the drive sprocket today with so many mods, due to lack of materials, I had to use an airsoft inner barrel as sleeve to couple the drive sprocket into the drive shaft.
In between the drive shaft and the drive sprocket is a silicone tube to act as slipper incase of weight over load, it has been forced-fit but not to tight.
Drive sprocket to track is the main problem, since there are no cogs on the drive sprocket and the tracks are made of rubber, the sprocket slips off during heavy load or action, often during turning where there is difference in track speed.
Here is a test run video:
As you can see, forward and backward drives are not a problem. but turning is a bit of a challenge (see 0:28) the traction of the rubber tracks adds resistance.
Next up? Blade elevation...
| + YouTube Video | |
#55
hi guys!im new to rc tank, and just bought my very first 1/16 snow leopard by heng long courtesy of centos, thanks bro!just got it yesterday, nandito pa sa office,,..iuuwi ko na mamaya sa bahay to test it out. Any help on parts or how to make it cooler would be nice!thanks guys!
and oh btw, i also made this tamiya track set into an rc full function..forward, reverse, left right..ecept it doesnt fire ammo.,planning
to convert this into a more interesting project.
heres the pic:
i used the board of an old cheap drift car using 3 AA batteries.
heres the pic:
#56
#57
i will sir, i dont have a camera here at the moment but will surely take some shot of it..basically its just the same tank as the others here.i'll try to repaint and redetail this..as of now im more concern of replacing those motors and tracks..mmm...any chances na available ang mga ganito locally?or somebody selling some parts?
thanks guys!
thanks guys!
#58
It can range from 2.5K -> 50K... Depending on the brand.
On a budget, go for Heng Long. 2.5K-6K (depending on your bargaining skills). Available in 168 in the divisoria area.Though they may be cheap, mind you, they are excellent platforms to deck out with details.
If your budget permits, you can also check out Tamiya. around 29K -> 50K. Available thru Lils. If I'm not mistaken, I saw a Tiger 1 and Leopard 2A6 in stock at Lils Makati.
Here are a few sites you might be interested in visiting:
http://www.rcuniverse.com/forum/forumid_369/tt.htm
http://www.rctankwarfare.co.uk/forums/index.php
For online stores:
www.etoarmour.com
www.rctankwars.com
Hope this helps.
For online stores:
www.etoarmour.com
www.rctankwars.com
Hope this helps.
Thanks sir.
#60
heres the pic:
heres the pic:
