Hobbywing ESC Settings ONLY >
Old 04-05-2011 | 06:13 AM
  #61
darrenoakley's Avatar
I was wondering when he would bite.
Didn't want to spoil the joke but nearly did with the amount of guys it hooked.
So can you send me a link Cherry?
darrenoakley is offline
Old 04-05-2011 | 06:14 AM
  #62
sizheng's Avatar
Thanks for your great work , Cherry. It's really a very good resource for all hobbywing users.
sizheng is offline
Old 04-05-2011 | 06:16 AM
  #63
irgo's Avatar
Originally Posted by cherry2blost
No you muppet check the date !!!
the date, today is 0405 ? what's wrong, it's out right ?
irgo is offline
Old 04-05-2011 | 06:23 AM
  #64
sosidge's Avatar
You know Cherry, the point of April Fools is that you make the joke on the 1st April, and you reveal it at midday.
Making the joke a few days later and then taking the p*ss out of someone who didn't get it makes a fool of you.
sosidge is offline
Old 04-05-2011 | 06:26 AM
  #65
sizheng's Avatar
Brothers,
I'd like to correct a mis-understanding for the boost and turbo timing.
In program 110119, Cherry's thinking is correct. The turbo timing will be added after the full throttle + delay time, even the boost timing is not added up.
But in the newest program 110211 , the turbo timing will be added after the full throttle + delay time AND + the remaining seconds of boost used up if exists (this is to say, turbo function activation must meet the requirement "ALL BOOST TIMING USED UP")
Since in most situations, boost timing will used up very quickly, so only very little drivers will feel the difference.
sizheng is offline
Old 04-05-2011 | 06:35 AM
  #66
cherry2blost's Avatar
Go away sosidge, you bought a speedo yet?
cherry2blost is offline
Old 04-05-2011 | 06:41 AM
  #67
sosidge's Avatar
Yes thanks, had Hobbywing tech in my car for 18 months. Very happy with my 10 month old software too.
sosidge is offline
Old 04-05-2011 | 06:58 AM
  #68
Originally Posted by sizheng
Brothers,
hi sizheng... i think u are very familiar with xerun 10.5t motor...
since it designed non-adjustable timing... any potential it quicker than any adjustable timing motor with all timing opened... fyi, i tested already on my last race at medium technical track seem ok to me with fdr 7.4 (seriously i was impressed with the speed)... any suggestion on big semi technical track with straight 200ft/62m...?
thanc for reply...
zamrioo2 is offline
Old 04-05-2011 | 07:30 AM
  #69
Monkeys punk's Avatar
Great the the muck has started to fly on this thread also.
To be honest sosidge irgo has been going on and on about the RPM log for so long and won't get any hints to stop so he deserves all he gets in my opinion. Come on you must be getting feed up with it to.
Oh also I am not a new member just winding up this is my second account as wanted to change my name.
Monkeys punk is offline
Old 04-05-2011 | 07:54 AM
  #70
TryHard's Avatar
Brothers,
So in effect, the settings Cherry has posted (and this is not ment as dig) replicates teh 211... using a long turbo delay to stop the turbo kicking in. even with a shorter delay, on the 0211 software, the turbo won't kick in until all the boost is added (plus other requirements).
In reference to the sweeper Cherry mentions, the turbo won't kick in until all the boost is added, regardless of the delay?
Just trying to understand the settings a bit more
Ed
TryHard is offline
Old 04-05-2011 | 03:31 PM
  #71
Ed
Well..... I was as surprised as you to read the changes made to 211 from 119. Am going back for ANOTHER day at Brooklands tomorrow and will try the following settings to start with....
34 Boost
30 Turbo
30 Slope
delay OFF
ACC 750
Start RPM 3000
Hopefully this will show some actual TURBO function down the straight
Using 213
For future reference it may be useful for the Factory to include a change log with each firmware update to tell everybody what has actually changed within the programming.
With the settings I was using though, not to refute the earlier comments, it did seem as if the TURBO came in part way down the straight, then the acceleration slowed as if it was reverting back to boost. Just an idea, how sure are we on what has been changed?
Hey Irgo was only pulling your leg, the whole RPM thing is getting a bit old now you have to admit it
Oh and just for a giggle here is my Bench test ESC
Old 04-05-2011 | 08:04 PM
  #72
TryHard's Avatar
34 Boost
30 Turbo
30 Slope
delay OFF
ACC 750
Start RPM 3000
Using 213
Hi Cherry,
I don't doubt you were feeling a turbo kick... it's possible that even halfway down the straight, not all the boost had been applied (by my rough estimate, car would need to be doing 35odd mph before the full level of boost had been applied), so the turbo conditions were met, hence the kick for the remaining timing was added. At least, thats my theory
The advantage I'm seeing at the moment, is that there is two ways to get full boost advance (smoothly, setting boost to 64, and never hitting full throttle), or using a combination of boost and turbo.
Ed
TryHard is offline
Old 04-05-2011 | 11:56 PM
  #73
Hi there.
What are the recommended settings when used in a drift car , 13.5T ??
A change in plan means I wont be racing with the Xerun (racing too many classes), so I thought I could use it in the drift car instead.
1101 is offline
Old 04-06-2011 | 07:41 AM
  #74
Tire Chunker's Avatar
Using 213
[/IMG]
This is my biggest gripe!!!!!! HW should never release an update without explaining what has changed. You can waste an entire day at the track trying to just get your car back up to speed with a firmware update.
Tire Chunker is offline
Old 04-06-2011 | 07:55 AM
  #75
daleburr's Avatar
+2
Each time new firmware is released it comes with some marketing crap about smoother/cooler etc, but nothing to tell us what has actually changed. Then there's usually some more unreliable posts from the sort of people who claim timing doesn't actually exist. Then if we're lucky sizheng posts something accurate, since he's the only one who actually understands the software.
daleburr is offline
