SC10 Thread
Old 03-31-2011 | 11:25 PM
  #5791
MarqueeRc's Avatar
Originally Posted by racer1812
Most people won't be able to tell the difference in handling to be honest, some will but most won't. One big reason to run the smaller spur is you simply don't have room for say a 30/87 combo, it just won't fit.
Thanks, precise and to the point ...I didn't ask that question but always wondered, and now understand..So sense i run on a medium to large, 1/8 scale, loose clay, outside track would i be better off leaving the 87 spur on the stock brushless 3300kv system?Thanks
MarqueeRc is offline
Old 03-31-2011 | 11:45 PM
  #5792
racer1812's Avatar
Super Moderator
AE lists 18/84 for the 3300kv. To run a smaller spur gear you would need a smaller pinon to keep the ratio the same and running anything smaller than an 18t isn't good IMO, the tooth angle isn't right and creates wear. In the end with a 3300kv motor you're not going to want a spur smaller than an 84 anyway.
racer1812 is offline
Old 03-31-2011 | 11:47 PM
  #5793
T-BirdJunkie's Avatar
18/84 is what they come with, but if you're hitting the track, it's way undergeared.
24/82 is what ThunderbirdJunkie would run.
T-BirdJunkie is offline
Old 04-01-2011 | 02:17 AM
  #5794
I run 22/84 currently with the factory brushless motor/esc.
rm25x is offline
Old 04-01-2011 | 08:19 AM
  #5795
JEFFs SC10's Avatar
Not sure what races or classes you all are running in but a 3300 kv motor would put you in the mod class with the fast guys.
A 17.5 motor with like the Novak Ballistic with 28/74 is like Its plenty of motor and power.
I ran timing on top of that and I was astonished but the temps come up pretty quick if you dont watch closely.
JEFFs SC10 is offline
Old 04-01-2011 | 08:49 AM
  #5796
LOSI123's Avatar
Can some one tell me what plastics are different between the Factory team and the normal kit & the RTR?
Like are they differnt material?
LOSI123 is offline
Old 04-01-2011 | 10:19 AM
  #5797
Wild Cherry's Avatar
SC10 plastic parts are all the made of same material , no graphite ,ect.
Wild Cherry is offline
Old 04-01-2011 | 11:18 AM
  #5798
ShortCourseOnly's Avatar
I was running a Ballistic 17.5 in stock class with the Kinetic and I added as much as 40 degrees with 24/75 gearing and temps were fine and top speed was fantastic while keeping low end. You have to change gearing in you add timing to manage temps. I would adjust the timing based on temps after 5 minute runs.
Now I jumped to Mod class with a 8.5t with a little timing and it is super fast!! It drive closer to my Jammin SCRT10 now.
ShortCourseOnly is offline
Old 04-01-2011 | 11:19 AM
  #5799
Aoh
anyone having problems snapping/shearing off the head of the diff bolt? did it the first time, thought it was a fluke, did it again last night. in all my years of r/c (gold pan 6 gear rc10 days) i havent had this happen before, but this is also with lipos and BL motors.
when i build it, i tighten it all the way and back it off until i can get it to slip, then give it a tad more until it doesn. this is done by locking the outdrives with allens and grabbing the gear with my hands. it usually ends up ~1/8th turn out. i also test for slip on the bench with the motor after the initial build.
Aoh is offline
Old 04-01-2011 | 11:32 AM
  #5800
Check and make sure the thrust washers have no dirt under and are clean....
Old 04-01-2011 | 12:51 PM
  #5801
AE RC10fan's Avatar
Default Gearing question
Thanks for the feedback on the gearing questions I had. Looks like I will be okay to start at 26/75 with the 17.5T Novak. I am still at a point where practice is going to help more than most setup changes. More power/speed doesn't necessarily mean faster lap times if you can't keep the nose of the truck pointed in the right direction.
My brushless system should be delivered on Monday, even more fun to be had!
Craig
AE RC10fan is offline
Old 04-02-2011 | 06:50 AM
  #5802
Default Carpet oval
Any good carpet oval setups out there? Stock or mod motored class it dosen't matter. I've been fighting it for 2 weeks now. Very sharp corners with long straights. Paper clip track, truck has alot of push in it.
super lates is offline
Old 04-02-2011 | 10:18 AM
  #5803
offtraxx's Avatar
push on carpet...
loosend diff (or thinner fluid for gear diff)
stiffer rear springs
batt all the way forward
add some weight (1/2oz on the servo works for me)
clean or use traction compound on the frt tires
that should get u started
my setup
frt arms level, gold springs, mid top hole, outter arm hole, 50wt oil, #2 pistons
rear, arms level, green springs, top inside hole, outter arm hole, 35wt oil, #3 pistons
I have about 1/4 inch of limiters inside the shocks to lower ride hieght
stock frt tires, hpi d compound rears.
offtraxx is offline
Old 04-02-2011 | 10:35 PM
  #5804
Registered User
Default Dodge Ram Body
Has anyone found a Dodge Ram body for the SC10?
Ryno B4.1 is offline
Old 04-03-2011 | 03:56 AM
  #5805
MarqueeRc's Avatar
No, 18/87 is how the sc 10 brushless 3300kv comes out of the box stock with.At least that it what it says on the manual??So what do you guys recommend i change the pinion to? Can go 19, 20, 21?I'm running on a larger 1/8 scale type track with a striaghtaway of about 25 -30 yards?
