SC10 Thread
Old 05-09-2011 | 10:12 AM
  #5941
bdyche's Avatar
Originally Posted by marvin2.5s
I have a quick question, my slipper clutch keeps glazing my pads and I have the FT V2 slipper clutch kit in my sc10, and yet it keeps slipping and glazing up my pads every run, and i aint even abusive to the truck. I have a 10.5 speedpassion motor and speedo in it, I rebuilt the gear diff a month ago and its been doing this for 7 months now, I have to sand the pads because if I dont they glaze up after every run. I just ordered the 4wd SC10 high torque pads to see if this will fix it, and no even if I tighten on the slipper alot it still glazes up my slipper pads. The only time i gun it is at the start of a race, but I've seen guys with 10.5s or 8.5 sc10's race and never sand down their slipper pads each race. Any help would be appreciated.
Keep tightening down on your slipper. You shouldn't hear the slipper working at all - if you hear it whining, it's too loose, and that will cause glazing.
bdyche is offline
Old 05-09-2011 | 12:21 PM
  #5942
Suspended
Originally Posted by T-BirdJunkie
Dunno, bro. Only been building AE shocks since the B2 came out. You know...back when they were good?
You know what they say when you assume
Savox servos perform well for a budget servo, but they suck a lot of juice. ThunderbirdJunkie needed to go beyond a capacitor and run a BEC on his.
Originally Posted by offtraxx
my favorite do far has been the savoz 1257. 139 oz at .07
anything around 120-150oz and less than .1 is good for the sc10. I would still stay with metal gears and glue ur servo saver together or upgrade to aluminum bellcrank to get the most response
Thanks guys for your responses. I'll check both out.
What do you guys think of this gearing on this set up:
Tekin RS-PRO - 8.5t Redline
84/17
Think I should gear up on the pinion? I've seen Kody Numedahl's set up running a 20t on his 8.5. Although, his gearing was 87/20. Not 84/17 -- on loose dirt outside track (large track)
Which is what I'll be running on.
Think I'm undergeared with a 17?
Sarinexia is offline
Old 05-09-2011 | 04:12 PM
  #5943
Suspended
Lively thread :-)
I'll get reading haha!
Old 05-09-2011 | 04:54 PM
  #5944
nsx_23's Avatar
Whats a good baseline for dirt? I'm running stock with 1/8 of a turn counterclockwise atm...
From reading the manual, the nose is supposed to lift slightly when you apply the throttle when holding the rear tires down?
nsx_23 is offline
Old 05-09-2011 | 05:00 PM
  #5945
HAD A THREAD POST OF MY PERSONAL BUILD BUT IT GOT CLOSED..
NOT POSTING ANYMORE PICS OF THE BUILD BESIDES THE BOX PIC
THANK THE SUPER MODORATOR FOR CLOSING THE THREAD.... I DIDNT DO IT
slick1 is offline
Old 05-09-2011 | 05:09 PM
  #5946
Jmuck69's Avatar
Good for the moderator! We do not need multiple threads on the same vehicle. BTW, this is the thread for the 2wd SC10.
Jmuck69 is offline
Old 05-09-2011 | 05:16 PM
  #5947
MarqueeRc's Avatar
[QUOTE=slick1;9086996]HAD A THREAD POST OF MY PERSONAL BUILD BUT IT GOT CLOSED..
Regardless, this is the wrong thread as your pic shows a Sc10 4wd kit, and this is the Sc10 2wd thread...The new 4wd thread for the Team Ae sct is here and seems decent so far:
http://www.rctech.net/forum/electric...-modify-8.html
MarqueeRc is offline
Old 05-09-2011 | 08:54 PM
  #5948
chop73's Avatar
Default hex adapters
for my FT SC10!
If i run a hex adapting kit on all four corners which split six beadlock rims can
i use? What hex kit do you recomend?thanks for your time!
chop73 is offline
Old 05-09-2011 | 08:58 PM
  #5949
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Originally Posted by chop73
for my FT SC10!
The 0 offset ones for the ProTrac kit. RTFM.
T-BirdJunkie is offline
Old 05-09-2011 | 09:07 PM
  #5950
Cameron Kellogg's Avatar
for my FT SC10!
Wait for AE to get the parts out for the SC10 RS and use those parts on your FT.
Cameron Kellogg is offline
Old 05-09-2011 | 09:12 PM
  #5951
chop73's Avatar
what is RTFM?
chop73 is offline
Old 05-09-2011 | 09:15 PM
  #5952
what is RTFM?
Really Tightly Formed Mom?
Old 05-09-2011 | 09:33 PM
  #5953
chop73's Avatar
So
So it's not Read The F#$*¥ing Manual !!??!?
chop73 is offline
Old 05-09-2011 | 09:49 PM
  #5954
So
You missed the tongue-in-cheek memo
But yes, that's exactly what it is, lol
Old 05-10-2011 | 12:57 AM
  #5955
marvin2.5s's Avatar
Questions??
But isnt the slippers job too adjust how much power is being put to the ground so there isnt a burst of power making the truck tires spin all the time depending on the track? Im running at a loose low grip track so i do need the slipper to work properly. Well i'll try this and see by the way will the 2wd high torque slipper pads work on the 2wd? Reason i ask is because even tho it says 2wd sc10 the holes on the 4wd pads look smaller then the 2wd pads, so will i have to cut them out so they fit or is the pic on AE's website mis leading?
marvin2.5s is offline
