NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 03-22-2011 | 03:13 AM
  #4201
sizheng's Avatar
Originally Posted by zamrioo2
sizheng.... by theory, can we get 119 as low temp as 211 if we put the delay more and ramp lower than 18...?
Zamrioo, I really don't know that.
I think it depends on the driving style and the track layout, not the setting.
But in most cases, if the tuobo delay time is above 0.4s , I think these two versions are almost the same. Because boost timing is used up or nearly used up.
sizheng is offline
Old 03-22-2011 | 03:47 AM
  #4202
COBRARACING's Avatar
Originally Posted by JAM Racing
Thanks for the update and i believe it to be true this time but ill ask once again a simple question
Which Motor( styled and what identifiction marks) are being ROAR APROVED
We have some motors here but with the lack of detail on them exactly which ones being are being aproved and as i had to buy a speed passion in the mean time to keep racing
The hobby wing motors work well with their software and your work is appreciated but this lack of detail is very frustrating
Im sticking with hobby wing the stuff is incredibley reliable A affordable prices
All the best
This is what the motors for approvla look like
Dark blue are 3.5T,4.5T mod all with adjustable timing end bell
Blue are 5.5T,6.5T fixed timing mod
light blue are the 8.5T,10.5T,13.5T,17.5T and 21.5T all with fixed timing
The larger motors are the 1/8th scale 2000kv and 2250kv
please also look at the Hobbywing website for specs .It has alot of information go to 1/10th brushless systems and the motors will be on the bottom of the page .
thank you
regards Angelo
Attached Thumbnails NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-motora-b.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-xerun5_5t.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-xerun8_5.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-xerun_4168sd.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-xerun_4274sd.jpg
COBRARACING is offline
Old 03-22-2011 | 04:18 AM
  #4203
is there any difference in these two motor
13.5T Sensored Brushless Motor Blue BRCA
or
13.5T Sensored Brushless Motor Gunmetal
thanks
mwoods is offline
Old 03-22-2011 | 04:22 AM
  #4204
cannon's Avatar
or
thanks
SAME SAME
cannon is offline
Old 03-22-2011 | 04:58 AM
  #4205
sizheng have you run V3.0_110213 ?
and work's with Turbo ?
and what about the new updates, that Michael will release ?
flashrevolution is offline
Old 03-22-2011 | 05:00 AM
  #4206
Originally Posted by cannon
SAME SAME
Lol thanks
mwoods is offline
Old 03-22-2011 | 05:22 AM
  #4207
Originally Posted by darrenoakley
I found that taking it back to an early version of the Hobbywing 2 in 1 box fw first then updating with the new SP stuff was the only way I could do it. If I tried to just go from the out of the box fw the SP software wouldn't update.
This is the LCD box we are talking about not speedo.
So i got to downgrade from what it has to way back on the hobbyking menu and then install the new menu from sp on it. i bought the lcd box from hobby partz for 17.70 kinda hard to beat that.
tcb22185 is offline
Old 03-22-2011 | 05:29 AM
  #4208
cherry2blost's Avatar
Deleted
cherry2blost is offline
Old 03-22-2011 | 07:09 AM
  #4209
Originally Posted by cherry2blost
BRCA have only approved the Blue ones something to do with the possibility that the colour may make a difference to how fast the car goes ::sigh::
how strange .....
mite order one later ...
mwoods is offline
  #4210
darrenoakley's Avatar
That's what I did and it worked fine. Had to try a couple of time as sometimes I got the error in connection halfway through. Also this is how I got SP software back on my Speed passion speedo.
darrenoakley is offline
Old 03-22-2011 | 07:14 AM
  #4211
VooDooPH's Avatar
since the HW 1S thread is quiet, might as well ask my question here...
any set-up suggestions running 119mod with a SP 4.0 v2 motor? roll-out? (running 1S). Track is medium/large asphalt track with low/mid traction.
Thanks!
VooDooPH is offline
Old 03-22-2011 | 02:51 PM
  #4212
thank you
regards Angelo
So the Hobbywing XERUN Motors they sell at rcmart are Silver does that mean they will not be on the approved list ? In which case what is the difference ?
http://www.rcmart.com/catalog/rc-bru...t-p-33222.html
bigtree is offline
Old 03-22-2011 | 05:01 PM
  #4213
Hobbyking ?
Old 03-22-2011 | 05:18 PM
  #4214
is there a usa distributor for hobbywing esc's yet?
xl2beno1 is offline
Old 03-22-2011 | 06:19 PM
  #4215
irgo's Avatar
Default Hobbywing Cut-off Voltage
while the cut-off voltage is critical,
the esc Fan still not getting Cut-Off.
irgo is offline
