NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 03-18-2011 | 04:21 PM
  #4111
darrenoakley's Avatar
Sure a max RPM log is good but to use it as a method to stop motors from popping would be like shutting the barn door after the horse has bolted. If you want to stop them from blowing the best way in my opinion is to temp check after a couple of minutes running.
Like I say that's just how I do it though
I do think we are in danger of becoming lazy as in expecting too much from the speed controllers.
darrenoakley is offline
Old 03-18-2011 | 06:01 PM
  #4112
irgo's Avatar
Originally Posted by Shawn68z
I am not suggesting a MAX RPM status as a tuning aid, I am recommending it be available as a safety from blowing up a rotor. To be used the same as the high temp cutoff.
Shawn
Perfect answer shawn, you are the best here who understand it all.
Guys The meaning of Max RPM, in the Log is to be at Running your cars when Under Load / on track.
irgo is offline
Old 03-18-2011 | 06:06 PM
  #4113
cherry2blost's Avatar
Deleted
cherry2blost is offline
Old 03-18-2011 | 06:17 PM
  #4114
irgo's Avatar
you can't do it right with that, cherry,
hey cherry do you have any new video, for this thread i see you have, forgot with what your doing, making video is good, rather argument.
irgo is offline
Old 03-18-2011 | 06:30 PM
  #4115
Originally Posted by cherry2blost
Each motor wind has a 'limit' to how far it will rev, prior to dynamic timing this was easy to calculate as KV x Input voltage, ie 3000kv x 8v = 24,000RPM. The main differentiation between motors of differing brands was the KV which invariably took into account the amount of 'in built' timing on each brands particular 'take' on the motor.
With advanced timing it is a little more complex, however each wind will have its' own 'ceiling' RPM which it could theoretically reach if left winding up for long enough. dynamic timing has changed this by allowing us to add more current/timing (argue amongst yourselves that point) thus in effect raising the KV figure to a higher amount.
For example using my own data logger my max out RPM on the straight, with a HW 13.5T BLM, was 48,000 RPM, which using the above simplified example equates to roughly 6000kv that was with the full added 'timing etc etc' utilised. By changing the gearing I could either have it 'topping out' early or gear to 'top out' later, but one thing remained constant and that was the maximum RPM at approx 48k.
The settings that we change affect the rate at which the timing is added, as well as the maximum that we wish to use thus giving more, or less, acceleration during timing addition trading heat for acc or vice versa.
What i believe is being missed here is that the motor does not cease to increase speed once the additional timing has all been added but will continue to accelerate upto it's structural maximum RPM ie 48,000RPM.
Example: Boost Start 5000RPM, Slope 200/Unit boost 64 Units.
If you have started the 'boost' (hate that word) at say 5000RPM then you will have a relatively shallow but linear upward curve on the RPM, upon hitting the timing start then the rate of acceleration will change accodring to the ACC setting, giving a strong upward slope in RPM/Time, as the boost phase ends at approx 17,800 RPM, then the motor will revert to a linear path upto it's final limit of RPM's ie 48000.
If you were to draw this as a graph it would form an elongated laid down 'S' shape, it would seem that there is a consensus here that the RPM increase ceases with the end of the dynamic timing phase and using that theiory the motor would 'top out' at (in this example) 17,800RPM. This is clearly NOT the case as tested by us with data logging hardware.
Discuss........
PS
I hate to agree with IRGO but the data logging information is enormously useful in fine tuning gearing to allow you to tune the gearing / ACC to allow you to maximise the rotational potential of a given motor on the straight, however it is of little benefit in the twisty bits, unless you have, as we do multiple sensors such as Steering input, Throttle input, RPM, Motor Temp, ESC Temp, Current, and both lateral and longitudinal 'G' sensors. The only reading we are unable to take is the actual timing data, this would be useful to have to add to the data already being collected.
HOWEVER.....
Just knowing the Max RPM does not help, as this will not tell you how long the RPM was maxed out, thus not allowing for adjustment to track length conditions etc.
To gain accurate readings we found that the data needed to be sampled at 20 samples per second, based on the 8 sensors, that requires 160 samples PER SECOND, even with the large extended memory of our V4 logger this limits the data to about 20 minutes. Now this sounds a lot but what I am getting at is that it is NOT just a case of 'slapping' on some software for logging, but also allowing for memory to be available for the information. So I ask an open question of :-
'How much are customers willing to pay for this feature to be added to future models - allowing that there will be a considerable increase in production costs; because, as previously mentioned by myself, the HW range is the best value on the market BAR NONE giving the most BANG FOR YOUR BUCK of any manufacturer in the RC world. Or are we in danger of demanding so many applications to be added that the unit becomes as complex as, say, a GM with a price tag to match?'
Discuss.....
On a lighter note finally got my Eyefinity 3 way monitor setup running woohoo SUPER WIDE games lol !!!
cherry... do u have the report in the form of easy to read as graphs or tables or figures...? mind to share...
zamrioo2 is offline
Old 03-19-2011 | 01:52 AM
  #4116
Bishop's Avatar
New HW Xerun motors really are good, finally got to run mine (10.5T) last night after our last meet rained out...
I had doubts about how well it would rev given the low kv rating, and I was only going to run it with zero timing, but even though I'd say it does rev a little short of my old SP, it seemed a sweet overall performer last night.
Bishop is offline
Old 03-19-2011 | 02:56 AM
  #4117
Originally Posted by look
I have a question useing the super Extreme stock 60 amp esc
with sock settings the ones withe * besied the number on the newest sotware and 119
my duo 3 and duo 2 cog at the start both are set 0 timing
any ideas?
esc is new
Tried Other settings but still a bad cog at low rpm
Going to put the tekin back in and send this one in
look is offline
Old 03-19-2011 | 04:07 AM
  #4118
Deleted
Old 03-19-2011 | 04:09 AM
  #4119
Deleted
Old 03-19-2011 | 05:54 AM
  #4120
Default instructions
Pretty sure this might have been asked before but where do I find the setting descriptions and instructions to the 211 or 119 fw - even a pdf link will do
emerge is offline
Old 03-19-2011 | 06:41 AM
  #4121
Craig W's Avatar
have a look here http://www.cobrarc.com.au/
Craig W is offline
Old 03-19-2011 | 08:50 AM
  #4122
irgo's Avatar
What would lutach's say now about Hobbywing, wonder ??
irgo is offline
Old 03-19-2011 | 10:10 AM
  #4123
Deleted
Old 03-19-2011 | 10:28 AM
  #4124
Craig W's Avatar
Cherry what data logger did you buy
Craig W is offline
Old 03-19-2011 | 12:28 PM
  #4125
Default Setup
Originally Posted by Craig W
emerge is offline
