8T 2.0
I've used the Super Hot Shot 2 for a little while now and it works great. I recently used a buddy's Lipo ignitor and it works awesome. Definitely picking one up for myself. Both are great ignitors but the lipo one is really sweet. I didn't think I would be a fan of it at first, but after using it, it does work very well.
Looks nice. I've been using the DE bump-skids myself. They do the trick and blend seamlessly into the chassis. I will never use a rear skid again. They're too catchy and make the truck/buggy too inconsistent in sharp bumps.
[QUOTE=JAMMINKRAZY;8774173]From my experience you actually don't want any backlash. Tighter the better without binding.
In my experience,it would appear you need more experience with gears ! LOL !all gears need backlash !IMHO!!
[QUOTE=rc racer 103;8775060]
I use to set up my ST-R with zero backlash and break the gears in..it seemed to work the best for long life..once broken in I would set the backlash..
That's cool and all, but completely opposite from people's real world experience with this truck. Everyone I've talked to, says run them tight as you can. I've tried it both ways and running them as tight as possible without binding and using a good grease gets the best results by far. So I say to you, these gears don't need backlash...
That's been my experience as well. The problem with trying to run any back lash is that unlike in precise machinery these gearboxes are made of plastic, and pretty soft plastic at that. When you get outside in the summer heat and run a long main, the plastic gets soft and flexes. This causes the lash to become too big and the gears start skipping. Do this a couple of times and bye bye gears. If the gearboxes were all metal and didn't have that extra give you could get away with no backlash.
whats backlash
Another note, as the gearbox gets older and more beat up, it also will become more flexible which causes even more trouble. That's why it is a good idea to replace them pretty often. The aluminum bearing inserts do help some, but the gearbox still flexes.
