#3513
Boost 36
Turbo slope 12
Turbo 24
Start RPM 3000
Delay 0.2
ACC 300
FDR 6.9
#3514
I will be running my extreme stock in 1/12 on 1s and will be running a novak booster, do i cut the red wire from the speedo? And if i do does this affect the ability for it to be programmed via lcd programmer card?
#3516
Well actually it flashes red, though I supose it can look a little orange if you have the blue case?, and it will not flash red all the time, just at idle, it turns solid red under throttle and green at full throttle.
#3518
from rcfans -马达王 TITC 11.5组好盈电变设定
内齿比1.9 38-20 6.70齿轮比
0211 STOCK
启动模式 9,
进角 40
TURBO进角24
起始转速4000
换挡转速300
TURBO释放速度 18
延时0.2
任何设定都是需要符合当时的赛道和地面条件
这个设定可能对有些玩家来说是不够暴力的 但是对我来说是最舒服的 因为在15.9的最快单圈情况下最后几圈这个设定都可以做出16.1的单圈成绩
#3519
6.70 gear ratio within the gear ratio of 1.9 38-20
0211 STOCK
Start Mode 9
Timing 40
TURBO into the corner of 24
Start Speed 4000
Shift speed 300
Release rate of 18 TURBO
Delay 0.2
Any settings are required to meet at the track and ground conditions
This setting may not be enough for some players, but the violence is most comfortable for me because the fastest lap in the 15.9 case, the last few laps this setting can make 16.1 lap
Thought I would do this first
#3520
from rcfans - Wang TITC 11.5 motor power variable group set a good profit
0211 STOCK
Start Mode 9
Timing 40
Start Speed 4000
Shift speed 300
Delay 0.2
0211 STOCK
Start Mode 9
Timing 40
Start Speed 4000
Shift speed 300
Delay 0.2
#3521
Can someone please help me out here, am trying to add editable fields into this form, have limited skills in Office so hope someone will be able to help me to add drop down boxes / click boxes to the empty fields in the Form.
Help !!!!!!!!
Cherry
Hope a genius can help out, i know what I am trying but it is beyond my capabilities I am afraid
Help !!!!!!!!
Cherry
#3522
Just for those that have asked here is the link to my hosted version, hope it helps
Download Hobbywing_USB_Link_setup_V1.63_110119.rar from FileFactory.com
Cherry
Cherry
#3524
4Likes
Thanks for the confirmation.
