8T 2.0
Old 03-02-2011 | 09:27 PM
  #11536
dnebout's Avatar
Originally Posted by rider313
Split diff is not needed just sand some off the stock plastic top. Mine isnt as straight as Jammin's but darn close. And normally i run the transponder low but have it Velcro-ed uptop so i could swap it out for my SCT class quick. But a buddy of mine is lending me one so down under it will go again. looks cleaner down there.
Yeah I had it sanded on a previous center diff mount like you. Is that the Dynamite setup?
dnebout is offline
Old 03-02-2011 | 09:29 PM
  #11537
rider313's Avatar
Dont be afraid to sand the top plate on the stock center mount so you can get a straighter angle.
it is and i like it very much.
rider313 is offline
Old 03-02-2011 | 09:31 PM
  #11538
dnebout's Avatar
Originally Posted by inferno13
just checked mine for you, and there is just enough room to slide a peice of paper under.
Thanks for doing that for me Inferno. I appreciate it. This now tells me that I may not have a chassis problem.
dnebout is offline
Old 03-02-2011 | 09:33 PM
  #11539
dnebout's Avatar
That may be the difference. My old setup had the center diff mount ground down a bit. I changed it to a new one awhile back but can't remember when. Maybe that's what is different.
dnebout is offline
Old 03-02-2011 | 09:34 PM
  #11540
If I want to use aluminum front carriers/spindles do I need 10 degree 12 degree or the silver color set up?
Should I use the lrc blocks?
How bout titanium turnbuckles, if I can get them ridiculously cheap r they worth it?
I have the center diff mount should I use it on my buggy or truggy?
Matt Piva is offline
Old 03-02-2011 | 09:35 PM
  #11541
dnebout's Avatar
Yeah looks like it's impossible to have any brake drag from loops not retracting back all the way.
dnebout is offline
Old 03-02-2011 | 09:36 PM
  #11542
rider313's Avatar
For 9.99 you cant go wrong. its slick and has no slop like the stock linkage.
rider313 is offline
Old 03-02-2011 | 09:41 PM
  #11543
this might be a stupid question, but...... useing rubber gromets for the throttle servo to allow alittle absorb for servo, why would you use a stifferer for radio tray? kinda takes the hole purpose away from running rubber gromets doesent it??? again just curious?
inferno13 is offline
Old 03-02-2011 | 09:47 PM
  #11544
Integra's Avatar
Originally Posted by JAMMINKRAZY
Took a couple pics of my linkage setup for you. Notice how it is actually a bit angled towards the center diff at neutral and how at full throttle it is almost perfectly straight. Sorry about the dirty truck.
Matt, You should Know better then to be Cocking the filter like that, Do it one too many time's and the Neck WILL split at the Worst of times....Been there, Done that.....Wont be tweeking the neck ever again.
Integra is offline
Old 03-02-2011 | 09:50 PM
  #11545
ok, so not a good spot for questions...LOL
  #11546
dnebout's Avatar
Here's the plan. Newer used chassis from a fellow Tech member and fellow racer, Dynamite linkage, Savox servo (shorter and I'm out of servos anyway lol), Shave the center diff top (like I used to have it to straighten things out). Swivel ball end to carb a bit.
This plan may not identify what was actually at fault, but should hopefully get me through finals at DRC.
Wish me well! Thanks fellas for all the pics and the time you spent on looking at my problem. Gotta love RCTech!!! Your all welcome at my campfire.
dnebout is offline
Old 03-02-2011 | 09:57 PM
  #11547
rider313's Avatar
The grommets aid the servo for a little amounts. Like quick stabs of impact. the stiffener makes the whole tray move less and stiffer on a 1.0.
rider313 is offline
Old 03-02-2011 | 09:59 PM
  #11548
i have all savox 1268 servos and have had no problems. i had problems with hitec also but to many hitec lovers here to talk bad..
Old 03-02-2011 | 10:07 PM
  #11549
Sup guys, have any helpful answers on this ^
Thank u.
Old 03-02-2011 | 10:59 PM
  #11550
Oasis's Avatar
Not really..I run the bolts pretty tight so their is a small amount of play..the stock tray in my opinion has way to much flex and the the graphite plate helps, as far as the trays go from what I could tell their the same..right down to the material, the 2.0 moved the tray out away from the motor a few millimeters, I guess it's suppose to keep it from binding as much, all I know is with my Mugen 6T I don't worry about servo problems..ever..
Oasis is offline
