Team Associated RC8Be Thread >
Old 03-01-2011 | 05:35 PM
  #3781
GreggW's Avatar
Originally Posted by smagistro
hey guys thinking about grabbing an rc8b. i got a mamba monster and a neu 2200kv motor with 4s lipos. Just wondering what gearing i should run? any other tips on these buggys would be great.
19-20-21 is a good start. I run a 21 tooth with my Tekin
GreggW is offline
Old 03-01-2011 | 05:36 PM
  #3782
117's Avatar
117
Originally Posted by GreggW
my Radio has a R603FS receiver. Its not longer than 4 inches. I coiled it around the receiver and closed the radio box.
I need to measure the antenna on the R6114FF.
117 is offline
Old 03-01-2011 | 05:38 PM
  #3783
same kv? those seem high but i guess with the 46t spur i have really only ran like a 48t spur as the smallest on other buggies.
smagistro is offline
Old 03-01-2011 | 05:40 PM
  #3784
GreggW's Avatar
This buggy and the Ve8 have different gear ratios than say Mugen or Losi, which would run a 12-15 tooth and get the same effect.
GreggW is offline
Old 03-01-2011 | 05:45 PM
  #3785
ahhh good advice. seems like people like the 1900kv tekin in there.
Old 03-01-2011 | 05:48 PM
  #3786
GreggW's Avatar
Yes, very popular. If you are going to be running on the track there are many different configurations. 4S is ROAR legal, so to go with that most people will run 1900kV. Ive also seen 1400kv on 6S 1500kv on 5s and 1700-1900 on 4S.
I run the 2050 and I like it.
GreggW is offline
Old 03-01-2011 | 05:49 PM
  #3787
schnellschnell's Avatar
Hey I've been reading all the posts on wires, and seen the pics. Suddenly it occurs to me that the Deans wire I bought and the Tekin wire the RX8 came with were not copper - but silver in colour. Is that pre-tinned or is it another metal?
j
schnellschnell is offline
Old 03-01-2011 | 05:50 PM
  #3788
GreggW's Avatar
j
The factory wiring that comes with the RX8 is silver too.
GreggW is offline
  #3789
per4m28's Avatar
Originally Posted by Handbrake
This is the way i soldered my battery, and motor connectors to my speed controller on my Associated Tc5 and Tc6. I will do the same on my RX8 when it arrives. They are 3.5mm female plugs and i sat the outside ones in the grooves on the posts, and the middle one centered. This gives good clearance between all three posts. The advantage of mounting the wires like this apart from looking neat, is two fold. It makes changing motors a breeze without having to re soldier, and secondly it increases the surface area on the posts for the heat to disapate. To solder, just turn the speed controller upside down heat the connector and let the solder flow into the bottom of the female plug and surround the post and fill the groove.
Anthony.
Looks very clean and neat I take it that you change motors frequently to do this as Ive seen many do these types of quick connect for motor changes with different low resistance connectors would usually work but also risk the chance of failing connectors, this I feel is the reason that most would go straight connections thru solder less resistance and lesser connections with less possible fail rates as we all know these buggys take high impact and viabration is extreme.
per4m28 is offline
Old 03-01-2011 | 05:51 PM
  #3790
I run a 2200 / mmm in my sc8e with 15/46 setup... im not sure id wanna go any higher.
agarabaghi is offline
Old 03-01-2011 | 05:52 PM
  #3791
GreggW's Avatar
Does that have the same gear ratio as the buggy? Im pretty sure it does.
GreggW is offline
Old 03-01-2011 | 05:53 PM
  #3792
Welcome to the forum shawn ...
So why did you put your losi up for sale?
  #3793
yes it does
Old 03-01-2011 | 05:55 PM
  #3794
So should I be replacing my wiring with copper?
I made all my charging leads with that too. Drat.
j
Old 03-01-2011 | 06:02 PM
  #3795
j
Sorry, but I'm not getting this far into it.
Why bother replacing it with copper? There is less conductivity with copper and it's only used in most applications because silver is too expensive.
Silver is where it's at boys. We have the high end sensitive toys... use the high end stuff!
Sarinexia is offline
