Associated SC10
Old 02-28-2011 | 11:11 AM
Default Associated SC10
I plan on buying the Associated sc10 4x4 and I want to race it. It says the truck does not come with any of the electronics. Can someone recommend a high torque steering servo as well as a 550 brushless motor and ESC and pinion gear. As you can tell I am fairly new to the hobby. Thanks, Brad
iuecbrad is offline
Old 02-28-2011 | 11:13 AM
You want something to race or bash? expensive or cheap?
pirape is offline
Old 02-28-2011 | 11:18 AM
sorry here it is
ok great, if you want to invest on good racing equipment consider going tekin SC4x 550 motor or Novak ballistic 550
both great motors
for ESC ( electronic speed control) consider going Tekin Rx8 or RS-pro / Castle mamba max pro / Novak havoc or kinetic
3 with great names and reputations
as for servos I went with the fastest speed / torque ration with an Hitec 7940-th
Hitec, futaba, and much more are to consider
pirape is offline
Old 02-28-2011 | 11:23 AM
racer1812's Avatar
Super Moderator
sorry here it is
both great motors
Ballistic 550 won't fit without clearancing the chassis, it's too long.
Fixed it for ya Coaster, I should have added that part.
racer1812 is offline
Old 02-28-2011 | 01:33 PM
CentralCoaster's Avatar
It will fit with minor clearancing on the side of the chassis. The timing nub off the end of the can hits.
CentralCoaster is offline
Old 02-28-2011 | 03:47 PM
trickedout's Avatar
In the same boat only i have good servos..What are some other Cheaper but good esc and motors??
trickedout is offline
Old 02-28-2011 | 04:05 PM
Savox 1258TG is a great servo, super fast/tons of torque, and between $40-60 depending what type of promos they are running.
I am a Tekin guy but I did purchase the Castle MMP. $100 new and can handle up to 6S LiPo. My track is tight and technical so don't see the need for more than a 540 motor.
W1KK3D is offline
Old 03-04-2011 | 09:30 AM
Based on how most people I see drive, they'd probably be better off with a 540 with less power.
That is, if it can handle the extra heat.
I'm gonna try this 3800kv 4-pole castle because I have it already, then upgrade if needed. It has a longer rotor than a 540. I have a MMP, but these things don't have a good track record with 550 motors.
