Team Associated RC8Be Thread
#3196
1. A spare ESC
2. Purchase the http://www.rcscrewz.com/product_info...oducts_id/3412 Kit.
3. And anything else of high failure or susceptible to breakage.
For me, I decided on this car BECAUSE it was practically awesome and no need to upgrade right out of the box.
If I want to pi$$ money away I'll give my lady access to my account.
#3197
It only comes in polished and it's the pinion you would change more often then not.
#3198
And yeah, you can screw, unscrew, all day long if you want. But for convenience and simplicity, I'd just get an additional motor plate for your second motor. Thus, you can just pop off the pinion, pull the motor out, put the other one in and put the pinion back on. Mesh it up, you're off. It could be done in literally 60 seconds.
#3199
I dont have any experience with the rear skid. But the rest of the stuff is nice to have. Much better than stockers.
#3201
if i was a pro driver looking for every advantage possible i'd run without them, but i like to keep my cars in as good of shape as possible and i'm not looking to go pro racing rc's so i'm running them for the extra protection..
your choice.. they are so cheap anyways
#3203
Everyone,
In the spirit of RC tech's best thread (RC8be thread); I too will carry on the tradition of posting up the final pictures of my newly completed RC8be.
I am ordering the skid plates and the dust guards. Otherwise, she's pretty much done!
BTW, I want to do a cammie paint job like the one I've attached into this post. Different colors, but the same concept. Does anyone have any clue how to make this pattern happen?
And to all that have assisted me in this build with my questions and sharing all of your knowledge:
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!
#3204
What's a few mm anyway? I can't imagine this addition of a skid plate would play this much of a factor in the handling of the car, despite what part of the track your on or current conditions.
Wouldn't one prefer the protection?
#3205
Looks good!
Thanks Billy! Thanks for all of the help with the screw dimensions for the grid mount. Appreciate it!
<------ Check out the Pic! No more Losi xxx-cr up there! (the pics will just get better and better)
Not only that, but you can remove the diff riser with the Grid mount.
#3207
If you have a bunch of forward momentum and you hit a big enough bump causing the rear to bottom and you have a piece of plastic protruding as opposed to just smooth aluminum, it wil cause the rear end to be jostled slightly causing you not to track completely straight.
Yes, the majority of the times I run DE skid plates, but if I find myself getting knock around on a bumpy track, it's the first thing I remove.
#3208
I usually run a skid plate, but the track I run on once has a long whoop section that I couldn't go straight through. Tried a lot of things and found out it was the skid plate. Not as bad with the DE plates, and definitely worse with the Associated plates.
Although, they do have transponders and time laps as well as put out rewards and trophies at my buddy's, so maybe the skid plate will be off more than it is on if what you say is true with the handling.
I'll have to give it a few go's myself and get a feel...
#3210
I run the de skids on my losi's and I have not had any problems with them. They are beveled enough so whether it's plastic or aluminum dragging, it's not going to be that much. I still set my ride height based on the chassis and not the skid plate. They do wear down quickly. As thin as those skids by de are made, if they are hitting, I am willing to bet 90% of the time the chassis is going to hit the same thing. In fact, because they do wear down so quickly, I am considering just running without them this year and making it an annual maintenance item to just replace the chassis.
