Team Associated RC8Be Thread >
Old 02-17-2011 | 06:18 PM
  #2911
Originally Posted by DRUNKENMASTER
Extension? I don't run an extension. I run it under the battery tray then in between the center bulk head and the front chassis brace.]
I used to do this too but mine routed under the chassis brace.
I then went with a 3" extension so I would not be yanking on the ESC wire from the RX when I wanted to upgrade hotwire versions.
click
bohdi is offline
Old 02-17-2011 | 06:23 PM
  #2912
jmackani's Avatar
Originally Posted by Sarinexia
Could I get a link to those skid plates? Thanks
I had the same problem on my build (and that was last weekend). I slipped in a plastic bushing into each side so I didn't have to get in there as far with the nut. It's working perfect. But you're right, the tool they supply isn't going to fit. You will have to get a thinner wall nut driver or possibly do the bushing thing like I did. Just don't strip the nut!
The plates are for the VE8. The chassis has replaceable front and rear clips. They make aluminum ones that strengthen the center part from cracking. If you do not run them on the hot bodies, you are pretty much guaranteed to break the stock chassis.
jmackani is offline
Old 02-17-2011 | 06:24 PM
  #2913
click
Is this ok to run with the Tekin and a Futaba Receiver?
Sarinexia is offline
Old 02-17-2011 | 06:27 PM
  #2914
jmackani's Avatar
Originally Posted by spina1686
Hello everyone in regards to racing what battery setup is better 1 4s 5000 or 2*2s 5000 and what would be the benefits
4s is better in my opinion for the following reasons:
1. Weight, it's lighter than the other two combined.
2. Clean wiring.
3. Balance two 2s's together can be tricky without the right charger.
jmackani is offline
Old 02-17-2011 | 06:32 PM
  #2915
per4m28's Avatar
A 5.5 nut driver or thin wall socket would do it.
per4m28 is offline
Old 02-17-2011 | 06:37 PM
  #2916
sure can
bohdi is offline
Old 02-17-2011 | 06:46 PM
  #2917
sure can
Ok, ordering :-)
Still kind of annoyed though that I need to do this. But, it's needed.
Old 02-17-2011 | 07:08 PM
  #2918
Ok, ordering :-)
Ordered:
Along with a Losi Tire Balancer (since i'll be gluing my tires soon, might as well balance them!)
Old 02-17-2011 | 07:12 PM
  #2919
GreggW's Avatar
Ordered:
Do you know how to use the tire balancer?
GreggW is offline
Old 02-17-2011 | 07:20 PM
  #2920
blade329's Avatar
So, who is running an extension from the ESC to the receiver?
I can't see any way to get around it.
Now the question is, what kind of extension do I need??
I'm running a Futaba 4PL 2.4ghz. Thus, the Futaba J connection I would think is the correct one.
Thoughts?
I did. I ran a very long one so I don't have to pull up the tray if I need to disconnect my ESC for any reason.
blade329 is offline
Old 02-17-2011 | 07:24 PM
  #2921
I know the concept of spinning the tire around and watching where the heavy end is and counter balancing it with the putty....
Aside from that, do you know something I don't?
Although, the balancing isn't my concern. It's the gluing
Old 02-17-2011 | 07:27 PM
  #2922
blade329's Avatar
Originally Posted by slash_me_up
This is the motor I got, Someone just told me I should't use this motor. What do you guys think? I went with the truggy motor and 4s lipo thinking I would be able to compete with the nitros at my local track. Did I make the wrong choice? Please chime in your input.
http://www3.towerhobbies.com/cgi-bin...&I=LXWZJ7&P=ML
I personally wouldn't run this motor in a buggy for racing. Too much weight, torque and power. You will never be able to put all that power down on loose dirt tracks and wheel spin will make you loose traction at the worse times. You'll have to tone it down on the radio. Which to me defeats the whole purpose of getting the motor. I run a Castle 1.5Y 1800kv and I can keep up with any nitro out there, no sweat. It's all in the gearing.
blade329 is offline
Old 02-17-2011 | 08:14 PM
  #2923
jwmustang's Avatar
1 4s 5000 it is lighter and smaller than 2 2s.
jwmustang is offline
Old 02-17-2011 | 08:31 PM
  #2924
GreggW's Avatar
Agree with Blade. I wouldn't run anything larger than a 1900kv if you are serious about racing.
GreggW is offline
Old 02-17-2011 | 08:36 PM
  #2925
GreggW's Avatar
Gluing isn't hard. And balancing isn't bad. Just where you put the putty.
GreggW is offline
