A quick question for CC BEC >
Old 02-01-2011 | 12:00 PM
Default A quick question for CC BEC
I get my mamba max pro with motor today. A lot of people suggest to get a BEC and not use on board BEC. I probably will end up getting a CC BEC with that field link card. I saw a picture, where that card is connected to a usb. Can I use that method to program my CC BEC, without buying the other field link programmer?
BearIam is offline
Old 02-01-2011 | 12:28 PM
You will only need an external bec if you are using a servo that draws a lot of current, you may even get by with just a cap
The Field Link card will allow you to program the ccbec and the ESC with the Castle Link software
Cheers
crusey_aus is offline
Old 02-01-2011 | 12:39 PM
cap = capacitor?
How big of capacitor and between what do you connect it to?
BearIam is offline
Old 02-01-2011 | 12:42 PM
Plugs into spare RX slot to stop voltage dropping under load
Novak
http://www3.towerhobbies.com/cgi-bin...?&I=LXNRE0&P=7
Spektrum
http://www.spektrumrc.com/Products/D...ProdID=SPM1600
Cheers
Old 02-01-2011 | 12:54 PM
thanks.
I will try capacitor method first.
BearIam is offline
Old 02-01-2011 | 03:08 PM
The Field Link card does connect to USB and you can use it as a standard Castle Link as well as use it to update the preprogrammed settings on the Field Link card. I just got mine last week and it also included the USB card. Just make sure the first time you use it with a computer, just make sure you have an internet connection so you can update with the lastest software.
Jeffgusa is offline
