A quick question for CC BEC
I get my mamba max pro with motor today. A lot of people suggest to get a BEC and not use on board BEC. I probably will end up getting a CC BEC with that field link card. I saw a picture, where that card is connected to a usb. Can I use that method to program my CC BEC, without buying the other field link programmer?
Thanks |
You will only need an external bec if you are using a servo that draws a lot of current, you may even get by with just a cap
The Field Link card will allow you to program the ccbec and the ESC with the Castle Link software Cheers |
cap = capacitor?
How big of capacitor and between what do you connect it to? Thanks |
Plugs into spare RX slot to stop voltage dropping under load
Novak http://www3.towerhobbies.com/cgi-bin...?&I=LXNRE0&P=7 Spektrum http://www.spektrumrc.com/Products/D...ProdID=SPM1600 Cheers |
thanks.
I will try capacitor method first. |
Originally Posted by BearIam
(Post 8583281)
Thanks |
| All times are GMT -7. It is currently 07:01 PM. |
