BP racing engines
#61
very quick engine.. faster then a kangaroo on top end. slips little fuel. not pricey.
combine with a 2015 pipe.. very smooth. this engine needs a little more mid range.
cons: THE CAB! very poor ... NOVA got a better cab.
the tuning screws are ....loose, i hope they stay where they are.
over all from a newbie .... good value for money. will run it aginst the novas and see how this engine fair
#62
George, email me if you want one, otherwise A Main has them in stock, just a matter of time until they get them up on their site.
Someone wanted the crankpin size, will try to get that measured today.
Steve, I think the standard 735 compares more closely to the Kangaroo in terms of power and performance. Both are very good engines. The 735RTC is a tuned engine with balanced crankshaft. It is identical to the 935RTC except for the number of ports in the sleeve. Either of the 735's will work well with a 2015 or similar pipe and medium or short header. I have installed a 735RTC sleeve set in my 935RTC engine, and used the 2052 pipe and at GLARCRC (which has a long straight) I have had no problems making 5 minute run time.
I have not had an issue with the carb, specifically with the screws coming loose, but I will keep an eye out.
#67
#68
With the 735 'tuned' version, besides the ceramics and the balancing of the crank, is there anything else that is done to it?
Also, I would like to get one in the next couple of weeks. It looks like AMAIN is starting to get product. How soon will they have the 735RTC?
Thanks,
Steve
#69
I assume you mean compared to the standard 735?
The crankshaft, sleeve, rear bearing, and cooling head is what is different from one to the other. Same goes for the 935 pair. Next batch of engines is about 2 to 3 weeks away, about mid February. Shipment leaves Italy tomorrow.
#70
Thanks again for the info.
-Steve
#75
