NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 01-15-2011 | 12:53 AM
  #2341
blade072's Avatar
Originally Posted by zipp
here's the link Cobra posted:
http://www.filefactory.com/file/b4g9...are_110106.doc
download the word document and scroll right to the bottom for recommended settings
I tried the 11.5t recommended settings and it worked well. Compared to the previous recommended settings for fw518, motor temps for fw224 were 10deg celcius cooler with the same fdr (6.5) that i was running.
oh yeah i just looked at the documents on it..... all good
blade072 is offline
Old 01-15-2011 | 05:39 AM
  #2342
Ok, and where I can download fw508 ?
ezh_m5 is offline
Old 01-15-2011 | 05:52 AM
  #2343
COBRARACING's Avatar
you can download it from www.cobrarc.com.au
COBRARACING is offline
Old 01-15-2011 | 06:26 AM
  #2344
xrayal's Avatar
Originally Posted by Lohan
I feel like a plonka here - does 10224 supercede 518?
I have 518, so is the 10224 a newer firmware?
Is it smoother?
rodney......... you are a plonker
lmffao. come and see us mate, youve been away to long
xrayal is offline
Old 01-15-2011 | 07:11 AM
  #2345
SammyZ's Avatar
hey guys, i just ordered the newer justock club racing spec esc for 17.5 touring car. Im really pushing hard at my club to race at a spec level to make racing more fair. Plus turbo/boost is gay.
Do you guys know if this speedo is firmware updatable? it says you can but i want real hobbyist experience with this.
SammyZ is offline
Old 01-15-2011 | 07:22 AM
  #2346
it should be in the future, but for now there is only the firmware that it comes with it (at least in mine!)
Hatebreed is offline
Old 01-15-2011 | 12:25 PM
  #2347
What is latest version of software for programm box? On my its v1.06_100617
but I cant upgrade it - button an upgrade not to press:
ezh_m5 is offline
Old 01-15-2011 | 12:49 PM
  #2348
You should connect the ESC with the servo cable, then you see all the data.
Next to that the switch off youre car should be on and a 7.4v battery connected, just like you would normally drive, but then with the servo cable in the program box.
rbakker is offline
Old 01-15-2011 | 12:52 PM
  #2349
No , I need upgrade program box software, because its always show " Connecting PC"
ezh_m5 is offline
Old 01-15-2011 | 12:54 PM
  #2350
CFR's Avatar
CFR
Don't you mean the esc cable, the one that goes into the receiver
CFR is offline
Old 01-15-2011 | 01:00 PM
  #2351
True, been busy with nitro the last days...
rbakker is offline
Old 01-15-2011 | 03:19 PM
  #2352
njt's Avatar
njt
Just had my first meeting with the new updates 1224 firmware a. Big improvement over the previous.
Using a Team Powers Plutonium 17.5 motor i was able to keep up with my teammate who was using a Team Powers 13.5 motor and a Tekin.
Set up on 60amp speedo was
9 30 degrees boost
10 1.5d / 0.1 sec
12 6 degrees turbo
13 3000 rpm
14 0.1 seconds
15 350 rpm
Motor temp was 62c
6.5/1 Gear ratio
njt is offline
Old 01-15-2011 | 03:55 PM
  #2353
i have tried with update button on my justock with a lcd program box connected to my computer and it just shows the current firmware..
Old 01-15-2011 | 04:12 PM
  #2354
xrayal's Avatar
Default new 224
at our tight indoor track (9 second laps) any ideas for a starting set up? on 518 basicly all settings were on max but no turbo. the car was very quick but i would have liked more initial acceleration. top speed is not required as the straight lasts all of 2 secs! (20m long) fdr 7.4, with the new settings in comparison how can i get more intial acceleration? cheers al.
xrayal is offline
Old 01-15-2011 | 04:24 PM
  #2355
Default Need Some Assistance
Hi....I got my HobbyWing (ver 2.0) Xerun 120 Amp ESC/Motor combo 2 weeks ago.
Team Cobra sent me some software to unzip and load into my 2 in 1 program box, ( which I did).
My DeskTop says it is "Hobbywing USB Link V1.62".
When I open up the Software and Plug my 2 in 1 program box, the Hard Ware Version is HW310 V1.0
The Software Version is V1.06_100512.....
I unplug the 2 in 1 program box from the Computer.
I then plug the ESC into the 2 in 1 program box, plug in my battery and turn on the power.
The program box says V1.06_100512.
I press "OK' button. The programmer flashes "esc software ver 10_091218a_t" and then goes into the mode that allows me to set parameters of the ESC. I have the following options.
1 Running Mode
2 Drag Brake
3 Voltage Protection
4 DRRS Punch
5 Brake Force
6 Reverse Force
7 Initial Brake
8 Neutral Range
9 "AMTS" Timing
10 Overheat Protection.
Thats it.....No Boost or Turbo settings. Guess I did SOMETHING wrong. I dont know what I did incorrectly. The Instructions that came with the kit are no help. How do I get the Turbo and Boost settings to become Active?
Question.....Can I plug the 2 in 1 Program Box into my computer via USB,,,,,AND,,,,,plug the ESC into the Program Box,,,,,,AT THE SAME TIME?...It seems like that is the way it should work, but I have not done this yet, because I am not sure if it is advisable to do so. Again,,,,the Instructions are not much help....
Redharris is offline
