Like Tree4Likes
Viper RC -
Old 01-07-2011 | 10:57 AM
  #136
ohdeeuhm's Avatar
Ah, I can't wait to get my hands on the Vtrax system! Looks incredible man, keep up the good work. I'll definitely be running the Vtrax/10.5 in my XXX-SCT
ohdeeuhm is offline
Old 01-07-2011 | 02:43 PM
  #137
nikos2002's Avatar
Here is one of the sample Vtrax10's wired into my TQ SX10 2w - ready for the J Concepts race at LIR tomorrow - if I can get through the snow to get there.
Great install, easy to work with on set up and using the Pro Gauge is great, plug it right in - no unplugging the connection from the rx. Set up too like 10 seconds.
Can't wait.
nikos2002 is offline
Old 01-08-2011 | 05:43 PM
  #138
losi316's Avatar
well i pulled the trigger an order two viper motors a 17.5 and a 10.5,looking for gearing for both. i have a kyosho rt5 with lrp 07 shere, i dont have boost or timing advance. thanks
losi316 is offline
Old 01-09-2011 | 02:56 PM
  #139
nikos2002's Avatar
I would start one tooth higher than you ran before and then check temps.
BTW, A TQ customer won the 13.5 Buggy class at the J Concepts Winter Shootout. The SX10 2w chassis and Viper 13.5 were a great combination!!
Old 01-09-2011 | 03:27 PM
  #140
badassrevo's Avatar
Any news on the 1/8th systems?
badassrevo is offline
Old 01-09-2011 | 03:32 PM
  #141
Dlewis4's Avatar
When I talked to Weylin about the 8th scale stuff, its a ways off. Will be this season, but he is wanting to make it perfect before it hits the streets. No more blowing up speedo's!
Dlewis4 is offline
Old 01-09-2011 | 07:29 PM
  #142
losi316's Avatar
so I am thinking 78/21 to start for the 10.5 and 75/26 for the 17.5. should i stay below 180 on temps for these motors. thanks
losi316 is offline
Old 01-10-2011 | 05:34 PM
  #143
mini-dub's Avatar
That sounds like it should be a good starting point. Temps should be well below 180, but 180 is the upper limit I like to stay below for motor longevity. For offroad you should see average running temps around 120-140. Gearing is specific to track size and layout of course. Our motors are very high torque and smooth, I would recommend taking the most common ratios you were running before and go up a tooth or two. Thanks and let me know if you have any other questions!
mini-dub is offline
Old 01-10-2011 | 05:39 PM
  #144
mini-dub's Avatar
We're trying to release the 1/8 system by spring 2011. But most importantly we want to make sure it's the most durable 1/8 system on the market!
mini-dub is offline
Old 01-10-2011 | 05:59 PM
  #145
badassrevo's Avatar
Sweet! I am really looking forward to another Mfg stepping up to the plate and jumping on the escale band wagon.
I will definatly try one out.
Old 01-10-2011 | 06:28 PM
  #146
slaytanic's Avatar
If it performs well, is bulletproof, and upgradeable, you will own E-8th!
slaytanic is offline
Old 01-10-2011 | 07:52 PM
  #147
Default Thanks Viper RC Solutions
I just want to thank Willie and Weylin for giving me the opportunity to run Viper R/C in 2011. I will be running at Outback Raceway (club racing) and will have the 10.5 strapped into the SC10 looking to create some open mouth stares! I have already seen the motors perform and we actually had some sample pre-production esc's show up at the shop today to do some testing.
Kendall is totally excited and you guys wont' believe how cool these look in person. And the fact that every esc comes with its own programming card is incredible. I know other manufacturers that have done this, but you can definitely see the quality in the Viper RC products.
Once again thanks and believe me with the Viper RC, just like their tag line says, "THIS WILL CHANGE EVERYTHING!"
JT
JT_Amain is offline
Old 01-12-2011 | 04:14 PM
  #148
Lax Legend's Avatar
Everything looks sweet hopefully dealers in the midwest start getting these. I'm sure they will sell super fast. Can't wait to test these out and tell people about them at my track.
Lax Legend is offline
Old 01-12-2011 | 04:49 PM
  #149
nikos2002's Avatar
Got a chance to put some test time on the Vtrax10 esc this week. Like the motors it was silky smooth. I think you all will like the range of adjustments. Its super easy to set up and has a switch that won't get turned off by accident. I also used Viper wire and sensor cable with it. Everything worked really great.
Like the motors the esc has a great look as well and should be easy to fit in everything.
Old 01-12-2011 | 05:00 PM
  #150
lowroad's Avatar
when is the 1/10 esc available?!?! WHEN??!?!
lowroad is offline
