T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 01-04-2011, 04:59 PM
  #6751
macdude's Avatar
Originally Posted by schreff
Hey Mike,
Do what Goat did. He filled the diff with toothpaste(not sure which one) and chucked it up in a dremel. The toothpaste broke in the gears pretty nice. I know he moved shims around too, but not sure which ones. The diff I stole from him is as smooth or smoother than a Spec R diff. The only thing is that it doesn't hold up well in anything quicker than a 17.5. If you try to run mod with it, it might last 2 minutes before ripping the gears up.
What spec-r diff are you using? Is it the BD5 one? That seems to be what all the other cars that don't have one specifically named are using.
macdude is offline
Old 01-04-2011, 05:28 PM
  #6752
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Originally Posted by eddie10
Plain and simple. The u pro gear diffs are junk. There notchy as he'll and blow up very easy. There not worth even trying so save your money.
I wouldn't say they are junk. If you take the time and build them so there nice and smooth they last as long as you don't use them in anything faster then 17.5 boosted. And they're lighter then a diff too.
I built 3 of these diffs in this way and 2 of them are still smooth as butter. Larry has 1 and Schreff stole the other. The one that failed was lent to someone to try in 17.5 boosted and he ran it in mod. I will not name any names he knows who he is.
THE GEAR DIFF BREAK-IN PROCEDURE:
Take your diff apart and clean all the oil out. Leave it shimmed how it comes. put a dab of tooth paste(a kind with grit to it) reassemble with 2 screws holding it together. Spin the diff with a dremal(I have a old dog bone I cut off to put it the dremal), Spin the diff for about 2 minutes on a medium speed. You should feel it start to free up. Then take it all apart clean every thing very good. Put the narrow shim on the outside of the out drive and the wide shim on the inside with the gear. Make sure the out drive spins freely in the diff half when reassembled. You may have to spin the diff out drive with the dremel to get it free. Reassemble with what every oil your using. I used 10k. It should be nice and smooth. You may have to play with the amount of breakin time. 2 minutes seems good for the tooth paste I have. You could also use valve lapping compound. Tooth paste was just easier for me to get.
Maybe Hanulec will put "THE GEAR DIFF BREAK-IN PROCEDURE" in his wiki
Ron Goetter is offline
Old 01-04-2011, 05:42 PM
  #6753
hanulec's Avatar
Trader Rating: 28 (100%+)
MikeXray is talking about the Atomic/Spec-R SPR009-BD Gear Differential set (For Yokomo BD5 40T) - http://www.egrracing.com/shop/gear-d...0t-p-3961.html
GOAT - you need to make a login, son! I put it in.. but I need to fix the spelling. What the!
http://www.racerlog.com/wiki/T.O.P._Photon#Gear_Diff
hanulec is offline
Old 01-04-2011, 05:46 PM
  #6754
I'm a mechanic not a English major kid!
Old 01-04-2011, 05:51 PM
  #6755
hanulec's Avatar
no worries Goat. cya saturday...
hanulec is offline
Old 01-04-2011, 08:20 PM
  #6756
MikeXray's Avatar
Trader Rating: 73 (100%+)
Here is my Spec-r Wiki entry:
Open package, assemble per instructions, fill with 80wt shock oil, put in car, may need 2 10mm axle shims, mine did, slightly dremel driveshaft blades.
MikeXray is offline
Old 01-04-2011, 10:17 PM
  #6757
29TC's Avatar
Since u guys are talking about the diffs, what are you all using to clean the silicone fluids from the gears inside? I tried motor spray and that doesn't work.
I want to change fluids but can't get the damn diff clean.
29TC is offline
Old 01-05-2011, 12:07 AM
  #6758
E.J. Evans's Avatar
The uPro diffs are meant for 17.5 speed or slower.
I have tested the yokomo diff and it works well, even for modified.
Here is the part number:
Part# BD-500GS
BD-500GS - BD5 Gear Diff
They are a little hard to get right now.
E.J. Evans is offline
Old 01-05-2011, 01:37 AM
  #6759
old-man's Avatar
Trader Rating: 11 (100%+)
Default Alternative spool cups for uPro spool
Does anyone know if there are any alternative spool cups for the uPro spool? The stock ones wears out way too fast. I am running on 10.5T boosted.
old-man is offline
Old 01-05-2011, 01:55 AM
  #6760
TeamWTF's Avatar
Thats not good news... I just received one today for my 5.5 car!
TeamWTF is offline
Old 01-05-2011, 04:16 AM
  #6761
Luppi Stefano's Avatar
use Litemodz Spool, is fantastic!
use one-way pulley
Luppi Stefano is offline
Old 01-05-2011, 04:38 AM
  #6762
old-man's Avatar
use one-way pulley
I was looking at that too, but the Roche ones look a lot more promising at a fraction of the price but unfortunately they are out on them.
http://www.roche.hk/shopping/index.p...&product_id=61
old-man is offline
Old 01-05-2011, 06:24 AM
  #6763
Why donīt you use the original spool?
With the steel outdrives itīs very solid and cheap.
btw: Iīm running more and more with 2 gear diffs.
I use the UPro for 17.5 non boosted and the spec-r for 13.5 boosted and modified. Much less wear this way and lots of steering
Lutz is offline
Old 01-05-2011, 07:04 AM
  #6764
old-man's Avatar
Bling factor?
But honestly, the original ones work fine.
old-man is offline
Old 01-05-2011, 07:15 AM
  #6765
Martin Crisp's Avatar
Default gear diffs
I tried the BD spec-r diff as well, and it works well for mod, but it is much heavier than the top diff, so for 17.5 I use the top diff.
For 17.5 boosted, I also experimented with using a diff up front as well and found that as long as there were not long on-power sweepers, the gear diff up front was quicker than a spool up front, due to it`s better turn-in and mid corner speed. I found that going with really heavy 300k diff oil in the front, it had just as much push going into the corner as a spool does, but less drive off the corner than the spool. So I seem to like 10k (associated) or (100k xray) oil up front, as it is not too thick that it cause a big push but still has reasonable drive off the corner.
Martin Crisp is offline
