Team Associated TC6 Thread >
Like Tree20Likes
Old 01-02-2011 | 07:10 PM
  #1291
DaveW's Avatar
I know everyone will want pretty aluminum... but AE should make bearing cap/shocktower mounts with vertical ballstuds out of their tried and true molded CFRP.
THEN offer an aluminum option if it takes off.
DaveW is offline
Old 01-02-2011 | 07:50 PM
  #1292
It would be cheaper for AE to produce them in aluminum. The cost of making the molds probably wouldn't be justified in a hopup part.
Serzoni is offline
Old 01-02-2011 | 09:10 PM
  #1293
Originally Posted by franc furter
Has anyone been able to fit a hard bumper [tc5,xray,top,etc.] on the car yet?
i got the parma tc5 one and cut out the guts of it to match the tc6 one and it fits fine.
its not as tall as the ft one, but it will take alot more abuse
ed
Edwin Pibal is offline
Old 01-03-2011 | 04:27 AM
  #1294
JRXS_chris's Avatar
Cheers guys, the pivoting was a concern but doesn't seem to be an issue when bench racing. We'll see how it stands up on the track.
I'll see if I have any more CF scraps to mount using the two screws. I could just CA an extra bit on I guess.
Looking forward to the outdoor season.
JRXS_chris is offline
Old 01-03-2011 | 05:56 AM
  #1295
speaking of shorter turnubuckles, has anybody been able to use the inner (I believe it is 2b) setting on the knuckle with the 7b ackerman? i can't get less than 1-2 degrees of toe-in with the kit supplied turnbuckles so I went to the outer hole.
Brian Bosley is offline
Old 01-03-2011 | 08:49 AM
  #1296
Maybell's Avatar
Maybell is offline
Old 01-03-2011 | 09:46 AM
  #1297
Buckaroo's Avatar
Probably like the camber links, gonna have to replace them with shorter ones. Thankfully there are plenty of catalog items. Annoying, though.
** Does anyone know the largest pinion that can be fitted with the stock 87T spur?
Buckaroo is offline
Old 01-03-2011 | 11:24 AM
  #1298
Ahh just checking to be sure I didn't build something wrong. the front and rear camber turnbuckles seemed to require the shorter ones so the longer ones were the only ones left.
It is slightly annoying to have the longest camber link settings as the stock setup too.. although the car works really well, perhaps it doesn't need as much gain as other cars I have driven.
Old 01-03-2011 | 07:02 PM
  #1299
Just checked, 24 was the largest I could run without changing the mount or anything odd. so that would be 116/32 in 64p for those of us pulling the stock spur gear right now.
Old 01-03-2011 | 08:18 PM
  #1300
Short camber links in the rear are a must, IMO. Really locks in the rear of the car (on carpet at least).
pcar951 is offline
Old 01-03-2011 | 08:42 PM
  #1301
i1justin's Avatar
Ive got 87/26 to fit just fine
i1justin is offline
Old 01-04-2011 | 06:26 AM
  #1302
jhock's Avatar
The largest 48 pinion that will fit is 27 with a 87 spur
jhock is offline
Old 01-04-2011 | 08:23 AM
  #1303
DaveW's Avatar
My statement wasnt about cost... i just want the parts in molded CFRP.
DaveW is offline
Old 01-04-2011 | 10:51 AM
  #1304
Buckaroo's Avatar
Thanks everyone. Makes 6.44 the lowest possible FDR with the stock gear in 48P. Not very Sportsman/stock friendly for the high 3s to the 5s. Hopefully AE will be releasing the purpose cut TC6 spurs soon. Until then, I'm off to order some Xenon gears.
Anyone have any other ideas?
Buckaroo is offline
Old 01-04-2011 | 11:45 AM
  #1305
ed517's Avatar
i use the standard tc5 spur gears. there is 2 options to mounting the motor(thats what the lower screw slot is for on the mount) i have had no issues with this and ive been running this car 3-4 times a week. for 17.5 carpet i have a 78/25 gearing
ed517 is offline
