RC10B4.1 FT/WC
Old 12-01-2010 | 09:58 PM
  #1021
vr6cj's Avatar
u guys should post up more pics of your cars. This thread needs pics!
vr6cj is offline
Old 12-02-2010 | 04:26 AM
  #1022
Jason_R's Avatar
Originally Posted by D-Rek07
Have you guys been happy with the V2 shocks? I'm getting new ones for my rtr and wondering if i should get the V2 or the the Kyosho shocks.
Having had both recently, I'd say the AE shocks are just as good. A bit more mess bleeding the K shocks, but the body coating does make the K shock just a bit smoother (imho) but not enough that I can envision a performance difference.
Jason_R is offline
Old 12-02-2010 | 05:42 AM
  #1023
rc east's Avatar
The new shocks are great! I never had a problem with the old ones I just hated snapping that o-ring retainer in and out, now the're easier to build.
rc east is offline
Old 12-02-2010 | 02:16 PM
  #1024
What size reamer do you guys use on the arms of the B4.1? Where did you get it?
deker9 is offline
Old 12-02-2010 | 02:30 PM
  #1025
You need a 0.109-0.110" reamer, or 2.78-2.79mm reamer. I've not seen one anywhere yet.
Stealth_RT is offline
Old 12-02-2010 | 02:33 PM
  #1026
YankeeFan123's Avatar
I guess I could post an ad here for the most attention from b4 owners. Is anyone looking to get into short course?? I have a brushless Blitz I'm looking to trade for a b4 or b4.1. Please PM me if you have any ?
YankeeFan123 is offline
Old 12-02-2010 | 02:34 PM
  #1027
Anthony.L's Avatar
No reamer, just run it. Mine were perfectly fine out of the box and especially after a couple runs plenty free.
Anthony.L is offline
Old 12-02-2010 | 03:23 PM
  #1028
Number 34 drill bit. It seems just a tad bit undersized but if you run it through a few times it works perfectly.
Chris Jarosz is offline
Old 12-02-2010 | 03:31 PM
  #1029
Yeah, the new plastic arms wear out and get sloppy fast. No need to ream them out when new.
On a side note, is anyone else excited about the new AE oil/bottles? Finally AE half-weights, and the nicest new bottles of any company out there. I did not know that Lucas Oil Products is making AE oil. Ought to do wonders for consistency from bottle to bottle. Also nice that they print the CST number of the oil on the label as well as the wt. No more guessing what 'weight' AE oil really is.
Old 12-02-2010 | 05:17 PM
  #1030
UltegraSTI's Avatar
DO NOT REAM!!! if u get a really tight 1 then u can heat up the hingepins with a heat gun nice and hot then shove them in the arm and/or block and let cool. can warm the arm/block slightly too. the plastic will cool down much faster than the pin and it'll stretch just that fraction to free a bad mould/bound unit. otherwise...run it in.
R
UltegraSTI is offline
Old 12-02-2010 | 07:42 PM
  #1031
Jason Haas's Avatar
+1 on the plastic slopping out fast!
Jason Haas is offline
Old 12-02-2010 | 10:56 PM
  #1032
R
Uh... why not? All the factory guys use a drill bit...
SoCalRacerX is offline
Old 12-02-2010 | 11:09 PM
  #1033
Anthony.L's Avatar
Maybe on the old Carbon FT parts. But the new FT plastic parts do not need it. You will only increase the slop.
Old 12-03-2010 | 01:34 PM
  #1034
djtroy's Avatar
I had a serious push issue with the front so I made some changes.
Let me know what you think of my setup. I have 50wt red losi oil in the rear shocks running Bar Codes on the front and rear. I changed the shock oil in the front to 30wt. Im running brown springs in the front and black springs on the back. I moved the esc and battery to the front. i layed the shocks down in the front and moved the bottom shock bolt to the inside position on the A arms.
Its a bone stock B4.1 RTR brushless
djtroy is offline
Old 12-03-2010 | 07:55 PM
  #1035
Thanks all for the input on the reamer.
Anyone have any info on what is going on with availability of the B4.1 Factory Team kits, seems they have been back ordered for a while now.
deker9 is offline
