tune pipe cleaning?
Old 11-08-2010 | 07:34 PM
  #16
boomgagem's Avatar
They say it helps the pipe perform like it would when new, couldn't tell you for sure though.
I do it for looks, I can't stand seeing a filthy pipe.
boomgagem is offline
Old 11-08-2010 | 09:04 PM
  #17
ScottyM's Avatar
Originally Posted by hookem34
Whats the purpose of this? Keep your pipe looking good or making it perform better by removing the old crap inside?
Cooking in anti-freeze will clean the inside of the pipe also, which will renew the performance of the pipe. Sometimes it takes a few days to get it back to 100%..
ScottyM is offline
Old 11-09-2010 | 09:32 AM
  #18
Originally Posted by MIKE WELLS
The antifreeze/crockpot method is way too much work... storing the crockpot, smelling the stinky heated antifreeze, dealing with antifreeze itself...
Go to an autoparts store and buy a gallon of carb/parts cleaner. I use "GUNK" brand, I'm sure there are others. The gallon should contain a basket to set parts in for dunking. The solution is waterbased, therefore it rinses off nicely with soap and water.
Disassemble the pipe and header assy and put in basket and put in the can overnight. The next day, I remove the pipe and hit it good with some simple green, rinse it good in the sink and the pipe looks brand new. Everything wipes right off. You can do this with the oldest, nastiest pipe... works perfect. And you won't believe how much comes out from the inside of the pipe. When you are done, put the top back on the can and put it on a shelf.
X 100 on the Carb Dip.
Storydude1 is offline
Old 11-09-2010 | 10:50 AM
  #19
hookem34's Avatar
Default What's next?
Cooking pipes in antifreeze.....removing tires with acetone.......cleaning engines with brake cleaner......what's next?
Rubbing the chassis with Asbestos?
I hope the EPA does not read this forum...
hookem34 is offline
Old 11-09-2010 | 12:25 PM
  #20
Snowbum32's Avatar
Snowbum32 is offline
Old 11-09-2010 | 01:56 PM
  #21
bigjayjay1's Avatar
x2
bigjayjay1 is offline
Old 11-09-2010 | 02:45 PM
  #22
ScottyM's Avatar
Keep in mind eveything that people are postin they use for various different purposes are 100% legal to buy and own.. Asbestos is not legal to buy own or manufacture anywhere... So, don't go green police just yet..
ScottyM is offline
Old 11-09-2010 | 02:49 PM
  #23
hookem34's Avatar
Just having a little fun Scotty.....
hookem34 is offline
Old 02-10-2011 | 06:57 AM
  #24
energyracing's Avatar
Hey Guys does this method ruin the finish of a hard coated JP3 pipe?
energyracing is offline
Old 02-10-2011 | 12:00 PM
  #25
no asbestos on the chassis but K-Y or Astroglide under the chassis helps with friction
RockStar_199 is offline
Old 02-10-2011 | 12:05 PM
  #26
+1
Old 02-10-2011 | 12:06 PM
  #27
AlanHall's Avatar
Im wondering who else has luck with this method. Storing a crock pot and anti freeze just to clean my pipe now and then sounds like a pain. This way it seems I can use it for alot more stuff.
AlanHall is offline
Old 02-10-2011 | 12:10 PM
  #28
kgombe's Avatar
remove the gunk inside.. is what i mainly do it for.. so for performance
kgombe is offline
Old 02-10-2011 | 04:29 PM
  #29
smccolp's Avatar
Its to get the soot off of the pipe inside and out. Carbon built up inside of the pipe from normal use can form deposits over time. These deposits will in turn disrupt the flow in the header and expansion chamber resulting in less than peak engine performance from your exhaust.
smccolp is offline
Old 02-10-2011 | 04:32 PM
  #30
smccolp's Avatar
Also I use aircraft stripper and a small flat head screwdriver to break up the carbon in motorcycle combustion chambers. Works great, let it soak 5 to 10min, scrape it a bit, rinse with carb cleaner, repeat as nec.
smccolp is offline
