tune pipe cleaning?
#17
Cooking in anti-freeze will clean the inside of the pipe also, which will renew the performance of the pipe. Sometimes it takes a few days to get it back to 100%..
#18
Suspended
The antifreeze/crockpot method is way too much work... storing the crockpot, smelling the stinky heated antifreeze, dealing with antifreeze itself...
Go to an autoparts store and buy a gallon of carb/parts cleaner. I use "GUNK" brand, I'm sure there are others. The gallon should contain a basket to set parts in for dunking. The solution is waterbased, therefore it rinses off nicely with soap and water.
Disassemble the pipe and header assy and put in basket and put in the can overnight. The next day, I remove the pipe and hit it good with some simple green, rinse it good in the sink and the pipe looks brand new. Everything wipes right off. You can do this with the oldest, nastiest pipe... works perfect. And you won't believe how much comes out from the inside of the pipe. When you are done, put the top back on the can and put it on a shelf.
#19
Cooking pipes in antifreeze.....removing tires with acetone.......cleaning engines with brake cleaner......what's next?
Rubbing the chassis with Asbestos?
I hope the EPA does not read this forum...
#20
#22
Keep in mind eveything that people are postin they use for various different purposes are 100% legal to buy and own.. Asbestos is not legal to buy own or manufacture anywhere... So, don't go green police just yet..
#23
#24
#27
#29
Its to get the soot off of the pipe inside and out. Carbon built up inside of the pipe from normal use can form deposits over time. These deposits will in turn disrupt the flow in the header and expansion chamber resulting in less than peak engine performance from your exhaust.
#30
Also I use aircraft stripper and a small flat head screwdriver to break up the carbon in motorcycle combustion chambers. Works great, let it soak 5 to 10min, scrape it a bit, rinse with carb cleaner, repeat as nec.
