Like Tree2Likes
RB Concept Engine Thread..
Old 10-17-2010 | 06:19 PM
  #1681
cdc
Originally Posted by tc5 man
not in the.. beginning of the race it does it later in the race it feels like i lose punch that might have something to do with the gear mesh or something ?
im pretty sure, the mesh got loose after some hard landings im using a king headz extented one piece engine mount and all the screws are tight and locktighted and the screws were tight .
its on my 1.0 t.
If the gear mesh got loose that could cause the it to slip though that would not cause the engine to bog.
cdc is offline
Old 10-17-2010 | 06:23 PM
  #1682
tc5 man's Avatar
Tech Prophet
sorry i remember it wasnt bogging it just felt like a rich bottom so it had to be the mesh like i was saying in the beginning of the race it was good !
i guess also when i pitted my pit man did open the tank lid so that proberty let air in you know what i mean ? and made it sound like a lean bog when i hit the throttle while he was refueling not a lot though.
now i did acutally have a lean bog early in the mourning but i fixed that so the idle whould drop down at my pit table i was doing it.
but the idle was a tad higher.. when it was fully warmed up during the main so i dint have a chance to fix it i did get to my track late in the mourning.
tc5 man is offline
Old 10-18-2010 | 06:43 PM
  #1683
tc5 man's Avatar
Tech Prophet
i forgot to.. add also i notice when i was upside down my wheels where moving so im guessing that the idle is a bit high my low end isnt too rich.
tc5 man is offline
Old 10-18-2010 | 06:52 PM
  #1684
cdc
If the wheels are moving at idle then the idle is high.
cdc is offline
Old 10-18-2010 | 06:55 PM
  #1685
tc5 man's Avatar
Tech Prophet
yea it wasnt doing it intill it gets around in the 200 s i just need to get to the track early to practice so i can get it fix.
it wasnt moving by its self on the ground just when i flip over i had to get on the brakes so the mashall could grab it.
tc5 man is offline
Old 10-18-2010 | 07:45 PM
  #1686
aznitronut's Avatar
If your wheels are moving, it can also be a clutch shoe dragging, or a clutch bearing getting ready to go out, that's real common.
aznitronut is offline
Old 10-18-2010 | 07:52 PM
  #1687
tc5 man's Avatar
Tech Prophet
i just put some losi hd bearings in and it spined smooth and free.
as for the shoe dragging do you mean alum burrs ?
tc5 man is offline
Old 10-18-2010 | 08:17 PM
  #1688
aznitronut's Avatar
They can drag if there is a weak or broken spring, but usually if there is a weak or broken spring, it will give you ghost like flame outs, or random engine dyeing.
Old 10-18-2010 | 08:33 PM
  #1689
tc5 man's Avatar
Tech Prophet
i did replace the clutch springs i forgot to add but i dint have any flamouts accept toward the finish it was upside down and shut off.
tc5 man is offline
Old 10-20-2010 | 11:33 AM
  #1690
Lille-bror's Avatar
Default X10 and B10
Gentlemen.
What are the difference between X10 og B10?
X10 more buttom due to 3 port and best in a truggy?
What about runtime? Are they similar?
And what else?
Thanks in advance
Lille-bror is offline
Old 10-20-2010 | 11:47 AM
  #1691
cdc
Originally Posted by Lille-bror
Gentlemen.
And what else?
Thanks in advance
The RB X10 is a 3 port. The RB B10 is a 5 port. I run a RB B10 in buggy. Lots of usauble power. I can get 12 runtime easy. Tunes easy and Holds a tune great. Very reliable.
cdc is offline
Old 10-20-2010 | 12:52 PM
  #1692
aznitronut's Avatar
The X 10 is the same as the Shark, the B10 is the same as the C6.
Old 10-20-2010 | 09:26 PM
  #1693
camocowboy's Avatar
Default RB selection
Can someone elaborate a little more on the differences in some of these motors and what you recommend. I am about to make the switch over from Nova's. I am thinking B10 or Cross 10, or both. What are the major differences in performace/application? Other motors to look at?
All input is welcome. Don, Tony V., Chris please respond or give me a call.
camocowboy is offline
Old 10-20-2010 | 09:38 PM
  #1694
cdc
The B10 is a 5 port and is best for buggy. The X10 is a 3 port and is best for truggy.
cdc is offline
Old 10-20-2010 | 09:55 PM
  #1695
secretsg's Avatar
No, the B10/C6 line has more overall power but is less fuel efficient. The power also comes on more sudden.
B10 is more suited for a truggy with the bigger tank. X10 is more suitable for buggy, it isn't really meant to be a truggy engine.
secretsg is offline
