8T 2.0
Old 10-03-2010 | 08:56 PM
  #9481
tc5 man's Avatar
Tech Prophet
Originally Posted by jmaxey51
the arms should be like a V shape in a way ... that is the hardest thing to explain over the net without showing
its a losi thing with the front arms like that lol not the others for some reason.
tc5 man is offline
Old 10-03-2010 | 08:58 PM
  #9482
losi_racer's Avatar
Originally Posted by tc5 man
oh ok have you tried the 7,20,3 when you ran the 1.0 t ? i would try 15k in the center but somebody told me that it would cause the tires to balloon more ?
again yes, i ran 7/20/3 and 7/20/5 when i ran the 1.0. i tried 10 n the center, it was more aggressive so its going to depend on how you drive, when i got the 1.0t i was only driving for like 2 months so the 20 n center was easier to drive
losi_racer is offline
Old 10-03-2010 | 09:06 PM
  #9483
tc5 man's Avatar
Tech Prophet
ok i got you however my track does get pretty rough and rutty so whould the 20 in the center make it harder to drive ? also in the losi manuel it said it whould give you more punch ? yea im running 10 in the center it is aggrestive i whould like it to be smooter actually.
tc5 man is offline
Old 10-04-2010 | 08:45 AM
  #9484
steve307b's Avatar
I'm sure this has happened to other guys, as it has happened a handfull of times in the past couple years, but 15 min into my main Sunday my ackerman screw backed out to where the screw hits the top plate when you turn and the truck looses almost all of the steering to one direction. So I had to drive another 15min this way. It also has me concerned about the strain it puts on my servo(7950) I know you can put a little lock tite in there, wich I have tried before and its still backs out. Any experiences/fixes with this would be great.
steve307b is offline
Old 10-04-2010 | 08:48 AM
  #9485
Frank L's Avatar
That didn't stop you 2nd place finish at Harvest. Maybe you should do the same thing to the other side. Jk. Nice job wish I could have been there. It screws into plastic so it needs a drop of ca glue loctite will make it back out easier in plastic.
Frank L is offline
Old 10-04-2010 | 08:51 AM
  #9486
jmackani's Avatar
You have to replace the nut on the under side of the ackerman. Lock tite will not help.
jmackani is offline
Old 10-04-2010 | 09:04 AM
  #9487
steve307b's Avatar
Haha Frank, Yeah we missed you...I have tried ca glue in the past when the hole has been stripped out , but this bellcrank was new, and the screws were tight before race. Just drives me crazy. I will try ca glue on the new bellcrank for next race.
Mack,Are you referring to the bellcrank plastic as a nut?
Old 10-04-2010 | 09:55 AM
  #9488
Steve after we talked I thought of a fix drill and tap a small 2-56 hole in the plastic to lock the ackerman screw in. And nice 2nd from bumping from last in the b main !! guess I'm going to have to step it up ...
rc racer 103 is offline
Old 10-04-2010 | 10:24 AM
  #9489
aznitronut's Avatar
When you are putting a screw into plastic, the best thing to keep the screw from coming loose, is CA glue on the threads, that will lock it in like loctite. If its come loose several times, its too late.
aznitronut is offline
Old 10-04-2010 | 10:26 AM
  #9490
jmackani's Avatar
I was thinking where the tie rod connects into the servo arm. That's where I have seen them back out before.
jmackani is offline
Old 10-04-2010 | 07:28 PM
  #9491
Toiffel's Avatar
Anyone know if the Pro_Tek Life receiver pack fits in the truck ???
Toiffel is offline
Old 10-04-2010 | 07:40 PM
  #9492
they fit, but require a little dremmel work to the battery case. they last forever. i have some for sale in the sale section. accidentally double ordered and didn't notice until to late.
nitroal is offline
Old 10-04-2010 | 07:41 PM
  #9493
aznitronut's Avatar
Not very well, I cut out the back side of the hump pack lid, but that's the only way.
Old 10-04-2010 | 07:50 PM
  #9494
Frank L's Avatar
Man why not just use the battery that was intended and designed for the 8ight vehicles. The losi lipo. It's like racers trying to find a better plug for an os engine. The p3 was made for a vspec but guys try other plugs like crazy. The losi lipo fits without mosd and lasts a very long time.
Frank L is offline
Old 10-04-2010 | 07:57 PM
  #9495
aznitronut's Avatar
Some guys don't have the money for the HV servos, but still get the weight of a lipo, without a regulator, plus long run time.
