8T 2.0
and they still work great!..i will keep it as a back up setup
yeah i have put about 6 gallons through on the same shoes and springs and i got the setup already PRETTY USED! i got 2 of the same exact setups used and was testing a motor that i bought used and didnt want to put the clutch bell all back on and fired the motor and as soon as i gave it a LIL bit of throttle i realized the shoes are gonna expand and then SNAP!...dang it lol...i snapped 2 shoes lol....this was like 9 months ago...but i havent got around to getting the 1 setup replaced so i just kept running the other setup for ALONG TIME!
yup the dynamite max lifes!...lol!....yeah they are worn but they still grab and work ok!....but thats why i built a new clutch setup!...
Whew glad you are building a new clutch. You are single handedly putting closed signs up in RC shops all over the country with 6 gallons. Hahaha. J/K
Use some plyers and feebly in the middle and move it back and forth as you twist it. This is why I like to let the pins rotate in the pin brace. If they become stuck in the middle of a main your handling will suck. If all else fails use a hammer and move it from end to end. I have had them get stuck until I started using an arm reamer.
Thanks again!
