RB Concept Engine Thread..
#1621
Hi folks.
Thanks for all of the imput in reference to helping me to get the old WS7 back on it's feet and out of the starting blocks with flying colors.
Here is my last little problem though. I think this one is a simple one.
I am running the engine between 220 and about 240 degrees.
I know I can let her run around 280,but, seeing is she is pretty new coming out of a full rebuild, I thought I would keep her kinda cool.
The problem is, bottom end seems a little soft. If I lean the LSN out some, I get the stalling effect. If I fatten it up, I get the high idle for a short period.
Any thoughts.
BTW, When she is about to run out of fuel and she goes really lean
Holy crap !!!
Her performance I would say doubles.. Burn outs, Lifting the front end
Stupid-crazy-fast Only noticed this 1 time..
Any thoughts.
Holy crap !!!
#1622
http://www.rbproducts.com/mainEn.php...E01010-SHARK10
Interesting. Looks like the Shark 10 is nothing like the Shark 9.
B10 crank/case + revised 5 port with 1 exhaust. 198 header + 9mm restrictor.
Sounds like a truggy engine, wonder why they didn't do a balanced crank like they did for the shark 9?
I think next up is for me to stuff a shark 9 crank into a B10 and see what happens... Either that or a B10 p/s into a shark 9 guts.
#1623
http://www.rbproducts.com/explose/RB...10-SHARK10.pdf
interesting engine
#1624
Well after braking in my K9, i never really used it after because i had a lean bog problem, i went a head and sealed up the back plate and fixed my issues, ran the motor this past week/weekend at the bryons fuel challenge and the motor was on fire. not even a gallon on it and she was ripping around. run time was a little over 8 possibly? never pushed it but was awesome. Was able to put the RB into the expert B main!
#1625
The engine is still fat and temps are still in the 220 range.
I have about 3/4 gallon on it now. maybe a little more. I started with 1 1/2 gallons and I have 1/2 left. But I have been trying to get another engine running as well. Hopefully, it holds up. Otherwise, I might have to break down save for something more current.
I hope I can keep up with some of the newer engines out there.
Werks B5.
Werks B5.
#1626
Had a huge wreck on our local track BIG jump which I'm sure we all have done. Continued on in the race and had a flame out 2 min after wreck. Thought that was strange so checked it out and found that the air filter had come off.(crappy cheep cable tie had broken). Pulled off back plate and removed glow plug to flush out engine with fuel and all seemed ok not really scratched or scored. Reassembled and seemed ok but kept flaming out. Got home and checked out the motor and found that I had screwed up on re assembly and it looks like I've done the piston skirt and back plate thing.
Anyway, just want to know where the best place is to get a new rod, piston , sleve and bearings for a B9. And should I go ceramic bearings. Does anyone do a complete rebuild kit.
Bit pissed about it but on a good note the wife gave me permission to buy a new motor and the B10 is now run in!!
#1627
#1628
I agree. Give A-main a buzz.
They ship quickly and stock
Buggy 9 did you say??
I checked stock, they are out.
here is there part number RBD01146-53] This the piston/sleeve/con rod.
Price is $169.00. Same price as my WS7. Cool.
#1629
Towers has it in stock.
http://www3.towerhobbies.com/cgi-bin...&I=LXWDZ9&P=SM
Use a coupon and it could be cheaper than amain.
#1630
Says here in the manual it's a 5+2 port with 3 exhaust (MES)
interesting engine
interesting engine
#1631
If you ever had a C6USA it will perform very similar to that engine. I have an on-road crank that is even more aggressive than the USA crank I run sometimes for truggy too. Overall I really like the Shark9 crank the most tho as I seem to get the best mileage with it.
#1632
alright i raced today with the #77 odonnell plug it defielty did run better and i dint have any flameouts at all and it give me a bit more punch. well in my, third heat my idle woulnt come down it was high so i went back to, my pit table and i tried to slow the idle down and richen the low end up a bit and it woulnt come back down to idle ? i think maybe i have a broken clutch spring or the clutch bearings went bad on me ? it was running fine during practice and a for a few heats.
by the way im getting the 53 pipe for sure now but would i have to go to a 50/14 gearing since thats a more torquey pipe than the 86 ? i was getting catch in the corners by some people because of the lack of torque.
#1633
#1634
yea, i will check the clutch as for the lsn it might be a tad rich or so but i forgot to mention that it would idle back down a little when i hit the throttle and than it wouldnt it so im thinking yea its ethier something with the clutch system or the lsn too rich.
2Likes
