NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 09-30-2010, 04:04 AM
  #1336
COBRARACING's Avatar
hobbywing motor info sensored motors
3.5T = 9100KV
4.5T = 7300KV
5.5T = 6000KV
6.5T = 5200KV
8.5T = 4000KV
10.5T = 3200KV
11.5T = 3000KV
13.5T = 2500KV
17.5T = 1900KV
21.5T =1300KV
these are actual kv ratings not like some who say 10.5T at 4500kv
COBRARACING is offline
Old 09-30-2010, 04:05 AM
  #1337
Originally Posted by irgo
cobra is it done? The rpm log firmware? Cant wait to see those.
not yet but very soon will keep you updated
Old 09-30-2010, 06:24 PM
  #1338
JKL1031's Avatar
what is v1.10_090323a_m ?? Is this the original software from the box?
JKL1031 is offline
Old 09-30-2010, 09:10 PM
  #1339
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Originally Posted by COBRARACING
Gathering the info and will post later this as you know there will be alot .
So the official sellers are unknown, but the gray market(the only market) is not legitimate. Are you a reseller, distributor, wholesaler...............how can you get customer service from legitimate sellers that don't exist?
I know most people that sell things actually try to get product to customers, it seems like the gray market is better at business that the authorized sellers. Hobbywing must sell out the front door and the back door. They don't even list on their site where racers can but their product.
Tire Chunker is offline
Old 09-30-2010, 09:33 PM
  #1340
izzyracer's Avatar
Trader Rating: 27 (100%+)
Originally Posted by AGNO
Hobbywing Xerun won the championship Tuscany(Italy) 17.5 Superstock A.M.S.C.I.
Winning setup
Hi Agno, thank you for sharing your ESC setup. I just installed my V2.1 120amp. It fits exactly on the TA05 tub chassis. I am using an old X11 17.5, copied your setup and will use as a starting point and just base on running it freely... WOOOOW truly night and day from just using my Cirtix Stock Spec. I will be doing testing at the Tamiya Track this weekend and I can't wait to see how fast thing goes. I will post my analysis after.
izzyracer is offline
Old 10-01-2010, 12:49 AM
  #1341
AGNO's Avatar
AGNO is offline
Old 10-01-2010, 12:54 AM
  #1342
AGNO's Avatar
Ok, you try it, it if the straight is very long (more than 35 meters) you can also use a lower FDR (such as 6,3 / 6,5) always check the temperature of the engine (max 70 °)
AGNO is offline
Old 10-01-2010, 01:43 AM
  #1343
I'm using a Xerun 60A v2.0 with a Losi 17.5T in my TA05R on a small carpet track, medium grip.
I started with the setup Hobbywing provided for 17.5, geared at FDR 4.8 (which was what I had with the 10.5 / GTB combo on the outdoor track).
It went well, temps never got too high, but it looks like most folks using 17.5Ts use higher FDRs. I presume gearing is the first thing you need to nail down, then everything else follows?
colmo is offline
Old 10-01-2010, 06:46 AM
  #1344
izzyracer's Avatar
I think this whole situation is due to hobbywing's deal with speed passion, not being able to sell in US market or at least advertise as such. Correct me if I'm wrong. What matters is we still have choice as consumers and it is really up to us to make that small effort to look for the better product. As far as warranty goes, only hobbywing should have the last say, and I don't think that is a problem. Hoorah for free trade!
Old 10-01-2010, 07:11 AM
  #1345
csracing's Avatar
Trader Rating: 22 (100%+)
So if you bought a brand new speed control from company XYZ and it burned up the first time you used it and HW charged you extra to fix it because you bought it from a "non-approved" source you would be ok with that?
I tend to doubt that.
As long as mine works when I get it I'll be happy I guess. Sounds like I'll be on my own if it goes bad or has a problem.
CSR
csracing is offline
Old 10-01-2010, 07:32 AM
  #1346
Born2Run's Avatar
I loaded my XERUN 120 with the 508 no timing software but i don't see any red light flashing as an indicator for the no timing software.Any ideas why?
Born2Run is offline
Old 10-01-2010, 07:52 AM
  #1347
AGNO's Avatar
Very strange, I used the 508 on both my Xerun 120 and the status LED flashes red each.
AGNO is offline
Old 10-01-2010, 08:09 AM
  #1348
sosidge's Avatar
Have you recalibrated the ESC to your radio?
sosidge is offline
Old 10-01-2010, 08:20 AM
  #1349
Born2Run's Avatar
Ofcourse
Born2Run is offline
Old 10-01-2010, 08:30 AM
  #1350
terryh's Avatar
The light isn't very bright, and it's a little higher up so a little more difficult to see.
HTH
While on the subject, I'm planning on running zero timing this weekend and could do with some advise on a suitable FDR. The motor is a GM13.5t with a 12.5mm rotor. Any help would be very much appreciated.
terryh is offline
