1/12 forum
you need a booster like the one TQ sells or the rc dynamic,4-5k maH is fine
http://www.rcdynamics.co.uk/Products.html
http://www.tqcells.com/TQBOOSTER.htm
Hey there, I'm taking on a 2nd class this year running 1/12th 17.5. I have success running a tekin rs with 203 software and a novak 10.5, but I'm not sure where to start with the 17.5. I read the last 50-60 pages and it just just touched on the subject and it was mostly with no boost.
My questions are:
1) is there a good set up for my tekin rs(boost turbo) 17.5
2)roll out. I read ppl are using 55t-60t pinions but thats for non boosted classes... Track size is 100x48
3) motor I was going to go back to novak for 17.5 is that a good choice or is there something better.
Sorry for all the noob like questions... I usually do my own research(ie read thread) but the season opener is around the corner and I like to order up everything asap
My questions are:
Phil, just sift a few pages back and u will see a couple post between myself and TrevCoult. That will give you more information on running a booster. Your other option is running a Rx pack, for example Amainhobbies Protek 200mah Rx pack.
Hi guys
I am new to 1/12th scale , i have just bough my 1st a Corally 12SL
i plan to use my Tekin RS speedo and a 13.5 motor , but how do i go about boosting my Lipo voltage from 3.7v to the needed voltage for the servo and reciever ???
also how bigger lipo will i need ?? 5000 or bigger ??
Thanks Phil
Thanks Phil
My questions are:
My questions are:
I don't have exact Tekin settings yet but 50/8 or 45/8 should be ideal for a novak with a bunch of timing already in it. In non-boosted 17.5 people should gear from 95mm to 105mm. Always talk roll out... not just pinion and spur.
Pick up some small spurs - 71 or 72t. Prs has them. Pinion sizes from 46 to 55 and u should be covered.
Why the JtG didn't work on a CRC carpet at the Worlds is a mystery. There are all sorts of theories about what is in the 'Euro' version of JtG compared to the US version, and what people were or weren't doing to their additive, but the fact remains that the JtG provided for the Worlds didn't work, and the Speedtech did. One day someone will tell us... HTH
the problem with a receiver pack is it will need charging after every run ,
i am totally new to 1s and 1/12th
i understnad i need 6v for the reciever/servo but what is best and safest ?
A reciever pack will only feed the reviever and servo the 1s lipo will power the speedo and motor , am i right in thinking this ???
A voltage booster just boosts the voltage from the lipo to the reciever and servo or am i wrong again (wont be the 1st time )
??Tech Fanatic
It will supply a constant 6V all the way through a run, it has a built in switch so easier to wire and fit on the car, it is built with military grade electronics so very reliable and little electronic noise. There's more, just click on the link written above and read. Not cheap, but definitely the best on the market.
I reviewed it a while ago, link is http://www.carsrcracing.co.uk/?p=183
Trev
Trev
Keep an eye on the Tekin RS thread and you'll get some good info on the RS.
Or direct from CRC: https://www.teamcrc.com/crc/modules....prodID=7719053
Don't forget that you will need the optional cross brace to use the long arm configuration.
2991Likes
