8T 2.0
#8687
#8688
ofna diff oil is thick and doesnt break down and its cheap , i dont know about kyosho thats just way overpriced losi diff oil isnt bad though its thicker than the ofna oil.
and mugen well you mind, as well run water in your diffs because its so thin.
so i would get the ofna oil since, it comes in a big bottle and its $7.00 .
#8689
#8690
I just got a set of 12 degree inclined for my truggy . Should i grind them for more turn in or are they fine stock ?? And also should i run the stock 3-3 rear plate, I have the adj ones on it now thanks
#8691
#8696
Quick question guys. After installing lightweight out-drives and aluminum hubs i noticed that with 129mm of droop the rear dogbone on the radio tray side was very close to failing out of the out-drive at full extension. I ran the truck two laps and the dogbone popped out on both laps, is there a fix or is there something i may have assembled incorrectly?
#8697
check your hinge pins.
#8698
#8700
Anybody here tried rock oil filter oil? How was it? Also whats another brand of air filters to use, I have been using power save, but A main is out.
