RC10B4.1 FT/WC
Old 08-14-2010 | 01:01 PM
  #121
claymonkey's Avatar
Originally Posted by aeRayls
Everything in mine went together great, and yes the roll pins come in a whole other bag, i think it was with the body clips and such. With the cva's you have to add a 3rd axle shim to both sides imo. My FTsc10 really needed a 3rd shim as well.
My tranny was smooth as butter and i tried cranking on the screws to see if it would bind and it didnt. MOst likely a bearing might be slightly unseated. Usually if everything is seated correctly and there is still a bind its just the case itself. The old cases were like this as well, some just didnt come out of the molds well.
The manual calls for 2 shock limiters front and rear and I only got 1 each for the front shocks. No big deal though its all driver preferance, i dont like that much limiting on the tracks i run on.
It is like building a whole "different" b4. the quality is much higher than even the FTB4 i built new in march( or the 6 others before that lol). Id say 85% of the kit is new/different.
I agree totaly and was my experience as well! Nice build and one of the best thus far no matter what brand.
claymonkey is offline
Old 08-14-2010 | 01:57 PM
  #122
I too couldn't find the roll pins until the end of the build. I only got one spacer per front shock so I used one .065 spacer instead of two (think they total .068). I didn't get any locktite in the kit but I did get two bags of steering rack parts. overall an excellent build. much better than the tc3 I got five or so years ago.
smojoe is offline
Old 08-14-2010 | 03:27 PM
  #123
VegasHB's Avatar
Originally Posted by Jmuck69
Double check that all your bearings are fully seated in the case halves. Second, it could be the topshaft spacer. I had to go to B4 rear axle spacer and shim accordingly. I found the topshaft spacer is a tad too long and causes it to bind when tightening down.
Yeah, I'll have to pull it apart again and double check.
Another thing just noticed is that the front wheels are either too narrow or the axles are too long, i can move the front wheels in and out about a 1/16th of an inch. The bearings kinda float in and out as well. I need to try another set of wheels first.
PS it's a FT kit.
VegasHB is offline
Old 08-14-2010 | 03:39 PM
  #124
mjk1210's Avatar
Originally Posted by hajjar22
What is a good wheel and tire setup for dirt grass and pavement that I can put on my t4.1
Try something like pro-line gladiators. They are a nice big square lug that will pull through short grass and dirt and also grab the pavement really well. You can run stock ribbed fronts with them.
mjk1210 is offline
  #125
hlb14's Avatar
got my b4.1 kit today... have a question though - where would you start pinion wise for a tight small indoor track with a 13.5/rs... 48 pitch right??
hlb14 is offline
Old 08-14-2010 | 03:40 PM
  #126
mjk1210's Avatar
23/78 or more. maybe 24 or 25/75.
mjk1210 is offline
Old 08-14-2010 | 04:23 PM
  #127
RatsacK's Avatar
I've just purchased a T4.1 RTR brushless and was wondering how tough these things are out of the box? I was planning to use it for bashing so I was wondering what I should upgrade to make it as tough as possible. I plan to put RPM arms on it but is there anything else?
Thanks!
RatsacK is offline
Old 08-14-2010 | 04:32 PM
  #128
Its a race car, you want a bashing car, get a slash.Its like comparing a sports car to a dump truck...
joker13 is offline
Old 08-14-2010 | 05:27 PM
  #129
RatsacK's Avatar
It's basically an E-Firestorm. You realise how many people use Firestorm's to bash with?
Have you actually ever owned a T4, Firestorm/Blitz, or Rustler/Slash?
RatsacK is offline
Old 08-14-2010 | 07:12 PM
  #130
racer1812's Avatar
Super Moderator
racer1812 is offline
Old 08-14-2010 | 07:48 PM
  #131
RatsacK's Avatar
Originally Posted by racer1812
Why are you laughing?
RatsacK is offline
Old 08-14-2010 | 08:09 PM
  #132
Quad Racer 34's Avatar
because its not close to an e storm..
Quad Racer 34 is offline
Old 08-14-2010 | 09:13 PM
  #133
mjk1210's Avatar
Thanks!
I would say not very tough for bashing compared to some other options. But good for racing.
mjk1210 is offline
Old 08-14-2010 | 09:15 PM
  #134
mjk1210's Avatar
Well...it has 4 tires on it...so it's not THAT different, is it?
mjk1210 is offline
Old 08-14-2010 | 10:15 PM
  #135
aeRayls's Avatar
Originally Posted by mxracer458
on the t4 what holes you guys running the upper tie rod in?which hole on the caster block and front tower?
Start with inside/inside on the front tower with 1 washer under ball stud. If its too aggressive add another washer. Still too aggressive move to middle hole on the caster block.
aeRayls is offline
