RB Concept Engine Thread
#511
The 2604 or the Capricorn 2662 work best.
I like the 2604 the best, the 2662 gives it a higher top speed but less bottom/mid power.
The 2630 is a useless pipe if you ask me, uses a lot of fuel and creates a lot of heat with less power as most other pipes.
If you want a nova pipe get the 2660 instead.
#513
for 25% nitro on a RB TJ10, you guys recommend adding a .1 or .2 shim?
i need to buy some shims - will these fit http://www.amainhobbies.com/product_...n/RB-Head-Shim
#514
#515
http://www.amainhobbies.com/product_...-020mm-0008-28
this one? :S
or this - http://www.amainhobbies.com/product_.../RB-Head-Shims
it says for .21 but also fits junior 9 etc
#516
looking at the packet of the picture, it says they are 0.3 thanks for that.
this one? :S
this one? :S
These are what you want:
http://www.serpentamerica.com/shop/p...6&cat=9&page=1
#517
They made a junior 9 .21 buggy engine also so those won't work.
but found them elsewhere
http://shopping.rcmodel.hk/product_i...10jfpk428o2625
or should i get the .15
http://shopping.rcmodel.hk/product_i...ducts_id=14708
#518
only problem is.. postage is $93.. lol
#520
On the RB K9/K10 run a total of 3 x 0.22 mm shims for 30%....They are the included shims with the engine...some of these engines came with 4 shims, some came with 3 shims.....however for 30% fuel 3 shims is about right, 4 shims is too many and lowers the compression too much IMO ..
#521
#522
#524
I dont know if nova plus will work, fit yes Im sure somebody knows. Seen the piston and sleeve set on A main hobbies under engine parts. From what I was told it has a little higher exhaust port.
#525
6Likes
ordered.
