Like Tree6Likes
RB Concept Engine Thread
Old 07-26-2010 | 06:56 PM
  #511
Originally Posted by DS Motorsport
The 2604 or the Capricorn 2662 work best.
I like the 2604 the best, the 2662 gives it a higher top speed but less bottom/mid power.
The 2630 is a useless pipe if you ask me, uses a lot of fuel and creates a lot of heat with less power as most other pipes.
If you want a nova pipe get the 2660 instead.
ill stick with the stock 2604 pipe then.
LiL_JaSoN is offline
Old 07-27-2010 | 04:59 PM
  #512
Can anyone tell me if the piston & sleeve, rod for a T9/10 will work in a R3?
Speedy Gun is offline
Old 07-27-2010 | 07:06 PM
  #513
for 25% nitro on a RB TJ10, you guys recommend adding a .1 or .2 shim?
i need to buy some shims - will these fit http://www.amainhobbies.com/product_...n/RB-Head-Shim
Old 07-27-2010 | 07:57 PM
  #514
Add .2 to run 25% also if I am not mistaken those silver shims are .3. FYI picco shims will work also.
Stlfc is offline
Old 07-27-2010 | 08:06 PM
  #515
looking at the packet of the picture, it says they are 0.3 thanks for that.
http://www.amainhobbies.com/product_...-020mm-0008-28
this one? :S
or this - http://www.amainhobbies.com/product_.../RB-Head-Shims
it says for .21 but also fits junior 9 etc
Old 07-27-2010 | 09:09 PM
  #516
this one? :S
They made a junior 9 .21 buggy engine also so those won't work.
These are what you want:
http://www.serpentamerica.com/shop/p...6&cat=9&page=1
Stlfc is offline
Old 07-27-2010 | 09:20 PM
  #517
only problem is.. postage is $93.. lol
but found them elsewhere
http://shopping.rcmodel.hk/product_i...10jfpk428o2625
or should i get the .15
http://shopping.rcmodel.hk/product_i...ducts_id=14708
Old 07-28-2010 | 04:59 AM
  #518
Well you need a total of .5 shims so what ever way you can come up with that number is not important. I always use 2-.1 shims and the stock shim when running 25% and the motors seem to like that.
Stlfc is offline
Old 07-28-2010 | 05:48 AM
  #519
2x 0.1 shim will be good
ordered.
Old 07-28-2010 | 02:40 PM
  #520
Maximo's Avatar
On the RB K9/K10 run a total of 3 x 0.22 mm shims for 30%....They are the included shims with the engine...some of these engines came with 4 shims, some came with 3 shims.....however for 30% fuel 3 shims is about right, 4 shims is too many and lowers the compression too much IMO ..
Maximo is offline
Old 07-28-2010 | 03:19 PM
  #521
DS Motorsport's Avatar
Yes, they are a direct fit.
The crankcase hasn't changed.
Only big change has been the T10RC crankshaft which is now balanced.
DS Motorsport is offline
Old 07-29-2010 | 09:07 AM
  #522
Thank you Mr DS, one thing solved working on the car next.
Old 07-29-2010 | 12:20 PM
  #523
musti72's Avatar
So Novarossi Plus 12-3SCT Piston sleeve fits on a R3? And where can I find a T9/10 piston sleeve set online? I will need a new P/S for my R3...
musti72 is offline
Old 07-30-2010 | 09:49 AM
  #524
I dont know if nova plus will work, fit yes Im sure somebody knows. Seen the piston and sleeve set on A main hobbies under engine parts. From what I was told it has a little higher exhaust port.
Old 07-30-2010 | 09:55 AM
  #525
Grinder's Avatar
Yes. The +12-3sct piston/sleeve/rod are a direct fit for the rbr3, rbm3, t10, t10rc.
Grinder is offline
