Xray NT1
#5446
If it was a pancar I would still lap you 6 times lol. But since your talkin smack I will even put in my SL3 and beat you. Hell, give me a fresh OS and I got you covered lol. I can't wait to see you run a rubber touring car this winter... I am going to spend all winter taking you to school.
#5447
oh please, Its a touring car. I run touring car in this area like its my Ho House.
Lookin' forward to this winter. Didn't have a carpet sedan last year. Got one on order tho... I'm sure you'll help me with the setup.
#5448
Well, you'll have to out-smack me to prove it. How about showing up at the Timezone Gran Prix in a couple of weeks. Should be a good turn out. Might find a bunch of people to smack.
#5451
rx7, some clutch pictures - http://s785.photobucket.com/albums/yy139/mikedoo3/
I'm using the Xray collet for Novarossi, I'm using an OS engine. Thickness of the shoe is about 4.5mm. I don't see anything wrong. I'm thinking about compressing the clutch spring in a vise... bad idea? or maybe it won't do anything, I don't know.
#5452
#5454
you could try that one for starts, only thing not stock would be the -.75 hexes. What track do you run at?
#5455
http://forum.teamxray.com/xform/inde...1152&setup=nt1
http://www.rrol.ca/track.asp
#5456
ill try there and the track i run at is a local track every other sunday in London ONT Canada
#5457
#5458
#5459
Hi i was puzzled with the same problem when breaking in a new enigne, clutch would not engage even revved at a pretty high RPM, i have tried pretty much everyhting but problem persisted , i brought my car to a track and have a local expert looked at it. the clutch was properly set and all number looked decent. When i started leaning out, the problem magically improved to a point it was gone. Xray clutch is rather sensitive, so once you start to leaning out your engine then it will work out fine. You numbers look fine, just give it a try hope it helps
#5460
18Likes
