RcRenew.com engine resizing and epoxy crank re-filling >
Like Tree3Likes
Old 05-14-2019 | 07:19 AM
  #2086
Rcrenew's Avatar
Originally Posted by sebtarta
Morning, is it necessary to add a shim between the front bearing and the cone? I have never done this, but I have read and been told it helps the race of the front bearing when the cone is not on it. If so, do we have a measurement or part # for this shim?
Thanks,
You can add a shim if you need to adjust the offset of your flywheel but it is not required. Also if you do add a shim it needs to fit the crank perfectly and not be larger than the inner race. I have seen many times people use large thin shims and they get bent back ( towards the bearing ) and eat up the bearing seal.
Rcrenew is offline
Old 05-15-2019 | 05:02 PM
  #2087
Default Will you accept?
hey lance,
wrote you you a message here about my B5 recently that I had wanted to send to you to get rebuilt. Wanted to know if you would mind if I sent it to you in pieces? I’ll explain..... I don’t disassemble my engine often, and want to get a repetition in doing that. So before I deploy, I wanna strip it totally down, inspect it, and learn a little more about the inner workings of a nitro engine. Would you have a problem with me doing that, and sending it to you completely disassembled to get worked on? Just curious.
xlrsd is offline
Old 05-16-2019 | 04:55 AM
  #2088
Thank you so much for the info. No shim it is then!
sebtarta is offline
Old 05-16-2019 | 05:25 AM
  #2089
Rcrenew's Avatar
Originally Posted by xlrsd
hey lance,
That's no problem go ahead and send it in and I will take a look.
Rcrenew is offline
Old 12-20-2019 | 12:04 PM
  #2090
Rcrenew's Avatar
RCR sleeve tools back in stock!
Rcrenew is offline
Old 12-20-2019 | 12:06 PM
  #2091
Rcrenew's Avatar
RC engine modifications at 2 day turnaround
Rcrenew is offline
Old 01-08-2020 | 10:24 AM
  #2092
blktransam's Avatar
love my rcrenew sleeve tool and ARO Lance knows his stuff
blktransam is offline
Old 08-06-2020 | 11:51 AM
  #2093
Rcrenew's Avatar
We have been working 6 days a week for over a year now to keep up with mods, sleeve resizing, machining parts and performing break ins. ( And I am very thankful for that ) That has not left much time for me to be on this forum but so if you guys have any question please email for a faster response.
[email protected]
Rcrenew is offline
